1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | I have a TH350 in my 56 that came from a 76 Camaro. My TF Speedometer is not reading. Disconnecting the cable from the tranny and hooking it to a drill it seems to work fine. It just dawned on me that the TF rotates counterclockwise. Does anyone know whether the Camaro drive gear is clockwise rotation or counterclockwise? Can I tell looking at it? If it is, will I need an adapter? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | everything turns the same way, if the speedo seems to work, disconnect the cable at the head and drive the truck to see if maybe the cable is not turning, either bad cable or trans drive gear
Bill | | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | Red58,
Gear looks good and cable is new and operates the speedo from the transmission end when hooked to my drill. What holds the gear in the housing of the speedometer drive? It appears that there is a groove cut inside the housing, possibly for an o-ring. Am I missing that? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes there should be a seal for a press fit, and if I recall right, there's a small metal plate held by 1 bolt that clamps the cable collar down ... might have a problem with the internal part that drives the speedo gear?
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Pull the driven gear out like Red says & look min the hole. The gear on the shaft may have walked away from the opening. There is a clip in the shaft that holds it in place. If it,s ok see if the teeth are wallered down in the center. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | Went to tranny shop yesterday and bought new housing made from steel and new gear. My old gear was toast. The shaft was worn to half its original diameter next to the gear. Tranny guy theorized it allowed enough play for the gear to not mesh with the one inside the tranny. Will put it all together this evening and let you know. | | |
