Having trouble with my '37 truck windshield replacement glass cracking.First one I think I cracked by using too thick of a window lace.Second cracked at delivery.Third used thin window lace ,then when almost done another crack.The glass is not too tight it almost looks too loose.Should I not use window lace?The original looked to have lace on it.If not what should I use to seal glass to frame.Any advice?! Thank you in advance !
