8 members (SammyC60, TUTS 59, 52Carl, Mike Roache, TooMany2count, Hawkman, Otto Skorzeny, 1 invisible),
101
Mod | | | Forums66 Topics128,101 Posts1,056,518 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | I am in the process of doing a sad 1929 1.5 truck. The cab was borrowed before I go the truck to do a hot rod. It would be nice to locate a replacement. I am not sure the original engine will be rebuildable. Also, would like to build a pair of adapters to dual out the rear axel. Has anyone got patterns or ideas? If you know of a derelict truck, with a cab available, and can share some ideas on a replacement engine, please help me out. Thanks, Alan
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Do I understand your right? no cab, bad engine, want a different rear...
What is it about the truck that you do like, or why must you restore a truck that is missing 1/2 the important stuff?
I'm sure it's possible, and you could have a nice 29 truck when done, but I would look for a different more complete project to start with.
Grigg | | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Hello Griggs and thanks for the observation. I also look at this project as a potential dumb thing to do. The end result has no where near the value of other projects I have. However, this project has a bit of sentimental interest for me. I know the history back to new. If I need, I will follow your advice and buy another donor truck in an effort to satisfy my sentmental streak on rebuilding the 1929. I also have a 1922 Dodge touring that I am putting together for the same sentimental reason.....what a hobby. Ideas are always welcome. Regards, Alan | | |
