7 members (Donf, 46 Texaco, Southerntruck, Nick in Manitou, Hotrod Lincoln, 2 invisible), 88 guests, and 2 robots.
Topics128,115
Posts1,056,633
Members48,450
#34815 12/26/2004 6:43 PM
When I changed the timing cover seal on my 235 (1957 era) there was what I would call an "oil-slinger" type of cup on the crankshaft end where it goes thru the seal to the pulley. Obviously it helps keep excess oil away from the seal. When I did my other 235 (1954)this oil slinger was not there. I made some inquiries and was told that it wasn't really neeeded so I put it back together as-is. My first 235 has stayed bone dry in that area whereas the second (without the part) still leaks oil. In fact there has been a history of oil leaking from that area and I am wondering if I should try to find this piece and install it. Being a loose fit I don't think it actuallys keeps any oil from lubing the seal but I may be wrong.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#34816 12/26/2004 8:53 PM
I have just been doing research on this slinger. The Chev parts books are not very clear but it looks like the slinger started in 1956. The slinger is held tight between the gear and the balancer. It is the same slinger as small blocks use. If you need one I have several.
My Blog
#34817 12/26/2004 10:36 PM
Pre'68 Dave. Thanks. I might decide to do the job again to stop the weeping. how much would you like for one? I am not far away from you.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#34818 12/27/2004 3:12 AM
It is best to use an oil slinger.
Truck Tinker
#34819 12/27/2004 5:50 AM
Just to confirm, the cupped or open part of the slinger faces forward, am I right? Like it would protect the seal. If I recall that is how I did it on my first 235.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#34820 12/27/2004 7:05 AM
That is right. You can't put it on wrong.
My Blog
