| | | Forums66 Topics128,203 Posts1,057,412 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 26 Apprentice | | Apprentice Joined: Dec 2007 Posts: 26 | I am hoping I am just not looking in the right place? Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | drivers door pillar - number might also be stamped on the drivers frame rail near the steering box - but the vin won't tell you if it was a Cameo, they didn't have a special indicator in the number
Bill | | | | | Joined: Dec 2007 Posts: 26 Apprentice | | Apprentice Joined: Dec 2007 Posts: 26 | drivers door pillar - number might also be stamped on the drivers frame rail near the steering box - but the vin won't tell you if it was a Cameo, they didn't have a special indicator in the number
Bill I don't even see a recessed area for the little vin plate? Did a 55 not have one? Thanks | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Don't remember if the plate area was recessed, but there should be at least a couple of rivet holes where the ID plate used to be. It's easy to build up a fake Cameo; all that's necessary is the fiberglass bedsides, a big-window cab, and some creative tinkering with sheet metal. I had a friend in the body shop business in California who built one that would pass all but a really detailed inspection. From 25 feet away, it looked like the real thing. Jerry
| | | | | Joined: Dec 2007 Posts: 26 Apprentice | | Apprentice Joined: Dec 2007 Posts: 26 | Don't remember if the plate area was recessed, but there should be at least a couple of rivet holes where the ID plate used to be. It's easy to build up a fake Cameo; all that's necessary is the fiberglass bedsides, a big-window cab, and some creative tinkering with sheet metal. I had a friend in the body shop business in California who built one that would pass all but a really detailed inspection. From 25 feet away, it looked like the real thing. Jerry Well I have a real one, but I'm looking for the vin plate? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Look for a small stainless plate spot welded to the upper door pillar. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | can't say what the engine # means, but the truck didn't come with a V8 because there's no leading V on the vin H255L = [6 cyl equipped] 1/2 ton, 2nd series, 1955, from the Los Angeles plant - the 7,998th one made there as numbering started at 001001
Bill | | | | | Joined: Dec 2007 Posts: 26 Apprentice | | Apprentice Joined: Dec 2007 Posts: 26 | can't say what the engine # means, but the truck didn't come with a V8 because there's no leading V on the vin H255L = [6 cyl equipped] 1/2 ton, 2nd series, 1955, from the Los Angeles plant - the 7,998th one made there as numbering started at 001001
Bill Thanks for the information. I am not really concerned about it not being a V-8 as it will be totally made into a driver truck for my wife. | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | According to an old Chilton repair manual I have, a "D" suffix on a V-8 engine number indicates a 1958-63 283 cubic inch engine. Jerry
