8 members (cmayna, Wally / Montana, Shade Baby, Goach2, Donf, dt235sd, Otto Skorzeny, Joe H),
60
0
Mod | | | Forums66 Topics128,119 Posts1,056,311 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 1 New Guy | | New Guy Joined: Oct 2007 Posts: 1 | hi. i got a 1940 chev 1.5 ton dumptruck. trouble is there is no VIN anywhere on this truck. it was bought from a wreckers and rebuilt in the early 60's for farm use so they never bothered with anything like that. wondered if anyone had any ideas on this or had similar problems. Thanks Brian
BrianpWalker
| | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | Good luck on that one. Being in CANADA those boys oughta be coming through for ya in a minute or two, wecome to the Stovebolt!
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy BrianpWalker, Welcome, in B.C. where I live, we can have a serial number created and applied to an "amalgamated" vehicle, it's called an assigned serial number, it was done to identify vehicles created from many different vehicles, I can't believe Ontario doesn't have some similar, hope that helps. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Can you get any kind of written statement or affidavit from the previous owners outlining the history of the truck? There should be a way to get it titled. Good luck.
Professional Novice
| | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | This maybe doesn't go perfectly according to the book but some times it easier dodging all the red tape. If you have a parts truck in the same era that hasn't been registered for like 30 or 40 years I would just take the serial number off that truck. The registration people don't keep records dating back that far. So when you go and register the truck the serial number that you put on the truck now belongs to it according to the registration people.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Brian, welcome to the bolt. I have used the wrecking yard outside of your town there, and they were pretty decent!
In Ontario they don't generally keep records after about five years of inactivity. Go to an MOT License office and ask them what you will need. You will probably need as sworn statement at some point. I used my lawyer for that. Eventually you will need to state an amount that you paid for the truck and they will charge you GST.
Can't wait to see some photos!
Fred
| | | | | Joined: Jan 2008 Posts: 21 Apprentice | | Apprentice Joined: Jan 2008 Posts: 21 | Brian are you still in need of a serial number plate if so send me an e-mail at [email protected] I think I might have found a solution for you. | | |
