| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34658 03/11/2005 11:33 PM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | For some reason my primary computer will not allow access to the Stovebolt forums, :mad: which is why I have not been on in some time. Finally got on by route of a computer we don't normally use for the internet. Have tried everything short of a reformat and still keep getting a "cannot find server" error. I have given up.  :confused: If there are carburetor problems for which you wish my assistance, please either contact me direct, or I can (and do) access both Chevytalk and VCCA forums. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#34659 03/12/2005 5:59 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Glad to "see" you around, I wondered what had happened. Your posts are always helpful. Brian | | |
#34660 03/13/2005 9:34 AM | Joined: Jul 2003 Posts: 106 Member | | Member Joined: Jul 2003 Posts: 106 | Jon, good to see you here again...I always look forward to your advice and insight. I've learned more about carbs from you than any book.
I get the same thing now when I log on(I use aol), but it gives me some other options to click on, you just seem to have to do it quick. Sounds dumb, but it seems to work for me, since typing stovebolt.com stopped working. I guess one of these days I'll have to bother Paul about it. Good luck and it's great to see you back!
51 Chevy 1/2 ton-Restored 46 GMC 1 1/2 ton-Farm Fresh
#34661 03/13/2005 2:52 PM | Joined: Jan 2005 Posts: 64 Member | | Member Joined: Jan 2005 Posts: 64 | There are 5 things to check before taking a whip to your electrons. They are in order:
Browser settings - make sure your security, privacy, & content settings are not impeding access.
Scan your system for Adware & remove - sometimes the insidious little boogers sneak in & throw switches that we can't see.
Firewall - you probably use software rather than hardware for this. Check the settings thru the admin interface to make sure that the site has not become blocked for some reason.
Router - sometimes the DNS firmware can bite the big one & the first indication is the inability to access certain sites (404 page not found error). Turn your router off for at least 30 seconds, re-energize & try again.
ISP - this is the last step but if none of the above work, call your ISP & report the problem. It may be his DNS server blocking or failing to update.
Hope that helps some, shipmate. One of these things is usually the cause of the 404 error when you know the page exists and is accessible by other computers.
Keep the bubble! | | |
#34662 03/13/2005 4:03 PM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | It's been my observation here that the moderators will have to resort to blocking an ISP to rid the board of a trouble maker.This might be your situation,you may have the same ISP as a person blocked from using the forums. | | |
#34663 03/19/2005 12:49 AM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Whatever it is, it is in my primary computer used for the internet. I can go to the shop computer (not normally used for internet) and access the site (same ISP, settings, etc.). Have tried deleting cookies, files, two different spyware deleting programs, internet settings, etc.
Will try to hit the site every couple of weeks or so from the other computer.
