2 members (55shaker, Paul_WNC),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 34 Apprentice | | Apprentice Joined: Feb 2007 Posts: 34 | Hey guys got the old bolt out and doing some work to it and i was wondering were yall find replacement blades. Mine has 13 inch blades and all the parts stores do not have them. I bought some blades but they will not stay on. Thanks Justin | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | I use Jeep or VW,they work pretty good. --------------------- Floyd
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Are you buying the refills or the whole thing? Ive usually had pretty good luck at Kragens(just for small stuff) Also, I remove mine during the summer,,the sun will cut their life in half. | | | | | Joined: Apr 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 38 | Not sure if they are across the country or a local chain but Pep boys carries the smaller sizes 10 -13 | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | I don't even try finding the small size, just buy (in your case) 26" refills and carefully cut them in half,install, have a second set on hand.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Try a marine supply company. Usually they are stainless as well. | | | | | Joined: Feb 2007 Posts: 34 Apprentice | | Apprentice Joined: Feb 2007 Posts: 34 | Hey guys thanks for the info. The only other problem i have found is the original arms the the blades fit into is to wide and all the replacements i have found are real narrow. I found a replacement on the website on this site. American classic truck parts, have any of you had dealings with them. I know some websites don't have quality stuff but i was just wondering about them.
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I've odrered from them before, no complaints.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | You might also want to check British Sports cars. I think I got mine from an MG. | | |
