0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#344720 12/04/2007 10:06 PM
it there a way to tighen up the gear box on my 65 chevy c-10. It has a lot of play.
why does it always happen to me??
Riding in the Passing Lane
Grab the shaft on top where it comes out of the box & see if it has any side play. If not Put the wheels straight ahead & loosen the lock nut on the adjustment screw on top of the box. Turn the adjustment screw down till the play is gone. Tighten the lock nut & turn the steering back & forth & check for binding. The adjustment screw may be frosen in the cover & you may have to put some penetrant on it & get creative. If the play is excessive & you really want to get it right you need to pull the gear & rebuild it. They are not hard to do on this model.
1972 Chevy c10 Cheyenne Super
Socket Breaker
Socket Breaker
Wrenchbender,
does this information only apply to the manual steering trucks? Is it different on the power steering equipped trucks?
-W
Originally Posted by Woogeroo
Wrenchbender,
-W
Yes the power steering is different. They generally don,t need adjusting but sometimes you can tighten down the adjustment on top 1/4 turn or so. If you go to far it will give you a weird high spot feeling.
