1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#34482 03/27/2002 4:38 AM
Anonymous
Unregistered
Anonymous
Unregistered
Have heard that the center section from a 55-62 Chev P/U will bolt perfectly into a 49 Chev p/u axle using the original axle housings, shafts and obviously the spring perches. This would also allow an open driveshaft. Sounds toooo good to be true! Any thoughts? Thanks
#34483 03/27/2002 5:01 AM
I was reading about doing this very thing on another website, They also said to weld up the part by the rubber bushing on the spring pad to stablize the rear axel since the torque tube is removed. Sounds too easy. Wonder why no elso has reported on doing this?
L. Day
#34484 03/27/2002 7:23 PM
I have done this swap, works great but you do have to address the pivots on the axle. I prefer to remove the pivoting mounts and weld on rigid pads. I have had a welded pivot crack.
Grant
1950 Chevy 3100
1952 GMC 150 (In Pieces)
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
