| | | Forums66 Topics128,128 Posts1,056,670 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | I currently have my 61 Burb in a million pieces and don't know what to do with the leaf springs.I have already replaced all the shackle bushing and pins .Do you disassemble and paint/powder coat, any advise would be appreciated.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If renewing is what you want just sandblast them. That's how they came originally, but if pretty is what you're looking for have them powder coated yellow. Cost will be $125/200
~Jim
| | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Yellow are you ate up, I was thinking more like flat black.Thanks for the advise
| | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | I sanded mine to bare metal and then painted them with POR-15. They look good. | | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | norcal49er, Thanks for the tip
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I pulled the leafs apart on a truck once, painted each leaf separately with POR15, then top-coated with chassis black. A lot of work for little reward.
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | Have then cleaned up and take to a spring shop to have holes punched in each end for Teflon pads. They will work better, be a lot quieter, and the ride will be greatly improved. Paint and assemble. Joe | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | ditto w/ joe H have the spring shop assemble them properely.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | No matter what you do they will eventually turn back to rust. Some things hold up better than others. A thin coat is best, its less likely to crack and flake off.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | I took mine apart, sandblasted them and coated them with POR-15. Reassembled them and they look great. I just don't know how long they will hold up. POR-15 if really tough stuff, yet flexible.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Thanks everyone I think I'll just take them apart clean and paint.Also the suggestion on the nylon anti-squeak pads I will do as well.
