5 members (Otto Skorzeny, Dennys28, Shade Baby, 49nut, 1 invisible), 62 guests, and 1 robot.
Topics128,120
Posts1,056,649
Members48,450
I currently have my 61 Burb in a million pieces and don't know what to do with the leaf springs.I have already replaced all the shackle bushing and pins .Do you disassemble and paint/powder coat, any advise would be appreciated.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
If renewing is what you want just sandblast them. That's how they came originally, but if pretty is what you're looking for have them powder coated yellow. Cost will be $125/200
~Jim
Yellow are you ate up, I was thinking more like flat black.Thanks for the advise
I sanded mine to bare metal and then painted them with POR-15. They look good.
norcal49er,
Thanks for the tip
I pulled the leafs apart on a truck once, painted each leaf separately with POR15, then top-coated with chassis black. A lot of work for little reward.
Have then cleaned up and take to a spring shop to have holes punched in each end for Teflon pads. They will work better, be a lot quieter, and the ride will be greatly improved. Paint and assemble. Joe
ditto
w/ joe H
have the spring shop assemble them properely.
Jim & Caroline
No matter what you do they will eventually turn back to rust. Some things hold up better than others. A thin coat is best, its less likely to crack and flake off.
Paint & Body Shop moderator
I took mine apart, sandblasted them and coated them with POR-15. Reassembled them and they look great. I just don't know how long they will hold up. POR-15 if really tough stuff, yet flexible.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
Thanks everyone I think I'll just take them apart clean and paint.Also the suggestion on the nylon anti-squeak pads I will do as well.
