2 members (Cosmo, Wayne67vert),
43
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 171 | The shop manual for my 54 1/2 ton states that the gross weight is 4800 pounds with "payload". It also says the "base truck" weight is 4200 lbs. I apologize in advance if I'm an idiot for asking, but is 4200 lbs what the truck weighs by itself (indicating that the max payload is 600 lbs)? I'm in need of a new floor jack and it looks like I need a 2 1/2 ton jack or better to be safe. Does that seem right? Thanks in advance. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Your logic sounds right, although your truck may weigh less than 4200 empty. (my 52 1 ton weighs 4400)
You may never lift the entire trucks weight with the jack at one time, but best to plan for a bigger jack that you think you need any how.
Grigg | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What I have found is the heavier the jack, the less the effort when lifting the truck. However, the heavier the jack the more space it takes up including the handle. Some of the larger jacks would be a real pain to maneuver underneath. My old one was a 2 Ton and it wore out. I believe that my new one is a 2 1/2 Ton.
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | I don't think it means that 4200 is the tare or empty weight of the truck. It's probably closer to 3100#. (That's where the 3100, 3600, etc. series came from.) Here is the page from the 54 Truck Shop Manual. The 4200 base is with the base tires. Most of the other series trucks have multiple GVW ratings depending on tires and springs, etc. I agree with the others get a jack bigger than you think you need, could be handy.
Professional Novice
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Frank50, I have never heard that explanation of the number series but it seems to fit. I wonder how far up the series that goes? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The 4200 figure in the shop manual is gross weight with 6.00-16-6ply tires. The 4800 figure is with 6.50-16-6 ply tires on the rear. That's the mfg. suggested weight limit for a fully loaded truck. Read the note. .....includes the truck chassis with lubricants, water and full tank or tanks of fuel, plus the weight of the cab or driver's compartment, body and special chassis and body equipment, and payload.
By the way, the series numbers have nothing to do with weight. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Weight of a 1954 Model 3104 pickup is listed at 3145 pounds. | | | | | Joined: Apr 2006 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 171 | Ghostrider- where did you get that figure from? It makes sense, though, especially with what Frank50 wrote about the series number (3100). So the empty truck (54 1/2 ton) by itself should weight around ~3100 pounds, and the *maximum* suggested vechicle weight is either 4200 or 4800 pounds depending on the rear tires. Well that clears that up.
I just wish the shop manual would be more clear about how much the truck weighs by itself. I understand the need for total weight (including payload), but it seems like a more useful number is the maximum payload weight. Perhaps that figure is in the owner's manual. I wouldn't think a typical truck owner would care how much the thing weighs; rather, he'd be concerned with how much he can haul around. Anyway, thanks all for the input. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I'm changing my model number from 221 to 175! Boy I feel better already...
~Jim
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I just wish the shop manual would be more clear about how much the truck weighs by itself. I understand the need for total weight (including payload), but it seems like a more useful number is the maximum payload weight. Perhaps that figure is in the owner's manual. I wouldn't think a typical truck owner would care how much the thing weighs; rather, he'd be concerned with how much he can haul around. Anyway, thanks all for the input. It would be impossible for the factory to give an allowable weight you can put in the bed. There are just to many variables that add up and must be subtracted from the max allowable weight for the whole truck. Small variables being how many people in the cab, tools under the seat, spare tire or not, full tank of fuel, grill guard, mud and dirt stuck in the frame.... Big ones being type of bed and size, dump bed or not, winch, PTO...... and on and on. The final word is what the entire truck weighs while driving down the road, that's what the engineers figure and the truck is designed for. Grigg | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Greg, The info is from the Standard Catalog of Chevrolet Trucks. Page 77 to be exact. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | fight nice boys....
Regardless of what a 54 year old document states. Drive it on your local scale empty and get your current empty weight. Chassis gross weight is pre-determined
I also remember either reading, hearing, etc. somewhere that the 3100's were 3100 wet weight, and about 2950 dry weight
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Just to confuse this issue: the 1954 Truck Data book gives a "Shipping Weight" of a 1954 3104 1/2 ton Light-Duty Pick-up as 3,115 lbs. This weight includes all regular equipment (grease and oil; 5 x 6.00-16 wheels/tires; 3-speed transmission; no rear bumper; no bed-side tire carrier).
"Curb Weight" with standard equipment is 3,255 lbs (must include 140 lbs for coolant and no gasoline; but, it is supposed to include a full tank of gas and a filled cooling system)?
Maximum GVW = 4,800
The Truck Data Book gives definitions of what is included in Shipping Weight, Curb Weight, and Gross Vehicle Weight
Clear as a bell? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Weight figures for each model, including the added weight by axle for most accesories, is available in the restoration pack for your truck.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | Just to muddy up the issue a bit more, I have a related question. On the passenger side of my 1/2 ton '53 is written in stencil GW 7000. It has the small extra springs under the rear axle, but that can hardly change the manufacturer's recomendations, so what gives? I've been carrying some pretty heavy loads the last 2 years, and the truck swims all over the road. I really have to take it easy with the speed sometimes. Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | That is over 2000 lbs above the manufacturer's maximum GW, is it meant to include the weight including that on whatever I might be pulling? It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | These weights all seem to be ficticious to me. Back in the days when we had to buy regular truck plates we had to have a weight slip to get a license plate. Most of us would take off the spare tire all extra equip. sometimes the rear bumper,etc. just to get the weight below 4000 lbs.True the gross weight stated on your tag is a maximum reccomended loaded weight. But 3100 lbs for a half ton truck sounds pretty light.Most of the 1960s 1/2 ton trucks weighed in MT at around 3800 to 4100 lbs depending on how many extras were on it.I would think that the older ADs having heavier body panels would weigh about the same. Only way to find out for sure is to have it weighed. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | One more thing to think about,back in the days of the AD,a rear bumper was an extra or acccesory,as were many other things. Also the weight in the manual is usually a dry weight,no fluids in the thruck at all.So if you figure what a full tank of gas,plus cooling fluid,and engine,trans. and rearend lube weigh it can make quite a difference.As for the reccomend gross weight ,I had a 1965 Ford F100 when I was putting in a new driveway,and garage floor.Many times I had a payload of 3500 to 4000 lbs.on it coming home from the docks. Not that I reccomend that much weight on a 1/2 ton but it steered just like it had power steering. | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | That's my own private theory about the weights and series numbers and it may be only coincidental that it "almost" fits some of the models. The weight info is in the "resto" pack info. Keith Hardy's site has lots of them on-line and the one for my 50 3604 pickup list the curb weight at 3695 lb. The 3104 pickup shipping weight is 3175. So....it's close. But I do wonder where did they get the series numbers? I know the Canadian 1/2-tons are 1300 not 3100.
Professional Novice
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Since my '54 GMC 100 had been out of license for over 30 years I had to have it weighed to get title. On a certified truck scale it weighed 3,460 lbs. with no rear bumper and very little fuel. | | |
