5 members (Donf, Shade Baby, sron48, Jon G, Bill Hanlon), 141 guests, and 0 robots.
Topics128,105
Posts1,056,208
Members48,436
Hey everyone, my old '53 1-ton is now starting, driving, and braking! (see link below). With the help of the kind sages of Stove bolt, I replaced clutch disc, wheel cylinder, water pump, starter, etc and pulled this one back from the maw of the crusher. (looks pretty darn good with the new hubcaps in the last few pictures - see the '53 link below).
One final issue is starter noise AFTER the engine starts - it makes a heluva rattle for a few seconds until the starter engage gear slings back and then the rattling stops. This only began happening recently. Before, the rattling just went on and on while the engine ran. It's seems that now the starter gear, as it successfully retracts with some effort, is chewing at the flywheel teeth. This is clearly not good. I read the thread here:
https://www.stovebolt.com/ubbthread...e&topic=0&Search=true#Post342126
and believe that I can clean or rebuild / replace the "starter drive" on the starter before any more damage is done to the flywheel. Is this the right approach, and do-able without finding another starter? Where can I buy a "starter drive"? Is that what I need? Will a good cleaning, or oiling something, do the trick?
3B Offline
Hy Colorado51three-quarter, the starter shaft can become "sticky" with old lube, the cold aggravates this. You can clean it up so the drive slides easily. Do you have the spring installed on the linkage, that helps to return the drive to its rest position, I'd post a picture for you, but I'm a mechanic, not a confusilator operater [she's at work right now] hope that helps.
