8 members (Gdads51, Gray_Ghost, EchoBravoSierra, LAROKE, frogfarmer, klhansen, 2 invisible),
185
Mod | | | Forums66 Topics128,198 Posts1,057,269 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34428 05/26/2005 8:15 AM | Joined: Feb 2005 Posts: 8 Junior Member | | Junior Member Joined: Feb 2005 Posts: 8 | I am currently trying to do a t-5 swap on my 1951 with a 57 235 engine. i read Robert French's article on it in the tech section and said hey that sounds like a good idea, so i got the tranny and started my search for a vega clutch disk to make it work. well i found that a 71 vega clutch disk had the correct 14 spline 1" hub pattern i need. Now for my delima, every part place and clutch company i have contacted has said they are obsolete. I need to find a 71 vega clutch disk desperatly, used, new, nos whatever i can find. Can any one help and maybe if robert french is out there he can help? | | |
#34429 05/26/2005 1:44 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | jkastner51. go to www.mongosgarage.com/tech/mongo/t5 and read his story on the t-5 swap. RON
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#34430 05/26/2005 5:18 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Most of the comments and/or articles I'm reading now from guys doing that swap are using Astro van clutches. As I understand it, Astro van clutches come in a couple different diameters with the correct number of splines. Astro van clutches should still be readily available for some time at the parts stores as production on the Astro van started in 1985 and was discontinued about two weeks ago, according to wdoftexas, with the last one rolling off the line at the Baltimore Plant.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#34431 05/26/2005 5:20 PM | Joined: Feb 2005 Posts: 8 Junior Member | | Junior Member Joined: Feb 2005 Posts: 8 | thanks for your help guys, i read though that with the astro van clutch you have to replace your flyweel and pressure plate with one from a small block and i am trying to keep those original. | | |
#34432 05/26/2005 6:18 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I bet if you take your original flywheel and pressure plate to the clutch house they can find something that will work for you. Find a place that only sells clutches. Talk to the oldest or most experienced guy in the place. Sometimes they can even make a custom one for you. Good luck | | |
#34433 05/26/2005 6:30 PM | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | jkastner51: What size flywheel do you have, using the discs I used you don't have to replace either of those. Don't spend the money for custom parts. MONGO | | |
#34434 05/27/2005 2:26 AM | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | you should be able to get a vega clutch or clutch hub from any clutch rebuilder in your local area. if not contact "Dougs Antique Ford Parts" in Little Rock Arkansas (501)455-2562. doug doesn't just sell those fxxd parts he rebuilds clutches & relines brake shoes. he does quality work for reasonable price. i'd reccomend staying away from the astrovan discs, they just aren't shaped right. the parts mongo mentioned are certainly worth looking at & like he says it depends on the size of your flywheel. i've learned a little more since i wrote the article & i believe a mid to late '80's 4 cyl. or V6 camaro clutch disc may be the ticket these also used the 14 spline input shaft. i believe it's what tom poterack ( http://community2.webtv.net/TOMPOT/TOMS1949CHEVYPICKUP ) used in his truck. if you want to swap some parts at a transmission shop the camaro input shaft & bearing retainer are already the correct length & don't need to be shortened. in spite of what i said in my article about them being rare & pricey around here ( i hadn't discovered ebay yet!) i just finished a build for my '50 buisuness coupe using a non world class F-body camaro V8 box. i took it apart & reassembled it using a top cover, tailhousing & output main shaft from an S10 box. the 26 spline input will have alot more clutches available for it, namely from camaro & full size pickups & the 2.95 1st gear is alot better. see william schicklings site( http://home.twny.rr.com/shickling/1940Chevy/T5.html )he's done the same thing. hope this helps, Robert French. | | |
#34435 05/30/2005 3:00 PM | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | jkastner51, let me know how your making out. thanks, robert | | |
#34436 05/30/2005 3:29 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | 1985 Astrovan Clutch, you do not need any special flywheel or pressure plate for this, that is what I used in my 52 coupe with a 55 truck engine. If you need me to, I can get the parts out of storage and show you a picture as I have since moved to an auto trans. Or you can just take the clutch hub you need to a clutch shop and have the correct diameter made for about $100 if you have $50 to throw away.
Chris | | |
#34437 05/31/2005 5:50 AM | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | I used an Astro van disc in my T5 swap. I have a 10 in. flywheel and pressure plate and the Astro disc is 9 1/2 in. It works perfectly. If the disc is slightly smaller than the press. plate and flywheel, it will grab better. The guy at the clutch house said they actually installed a 10 in. disc with a 11 in. set up, in the early Camaros for that reason.
Good Luck
'54 3100-235-T5 trans-12 bolt 3:31 '68 Impala 307/350 '78 Sportster/Original owner
