| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | My new pen came with two cup like pieces that are about 1/2 in long and fit over the pin. How are these used fellas?
Ridge dweller
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | These go inside up against the two holes in the hinge body. The actual hinge piece then slides in and you push the pin through all the pieces. I don't know if you have read the post below but this is the way to do it. They act as shims so the hinge going to the door contacts them top and bottom. If you drill as described in the post they will neatly fit into the new holes. At least mine did, I bought the kit from Classic Parts https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/328064#Post328064
