4 members (thekid1950, Peggy M, RoadsScholar, Hanks custodian), 164 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
#34402 06/01/2003 11:37 PM
Good eveing,
Went to the part store well in fact called 7 and went to 3 to find a intake gasket for a Chevy 54 235. Does the 235 have an intake gasket? All I can find is the gasket for the exhaust and it comes with 7 holes.
Thanks, Greg
1951 1.5 ton 4400
#34403 06/02/2003 12:19 AM
The intake gasket is combined with the exhaust gasket and it should be in three pieces. The round holes are the intake holes. You should have a little round collar for each intake hole. These are normally reused, not supplied with the gaskets.
1951 1 Ton Completed
#34404 06/02/2003 12:34 AM
Thanks, how many ports are in the head?
Does one port go for two cyls?
Greg
1951 1.5 ton 4400
#34405 06/02/2003 5:28 PM
I was referring to the gaskets between the intake/exhaust manifold assembly, and the head. There is a gasket that starts at either end, and one in the middle. There are three little rings and they fit into the head ports and into the intake manifold ports.
#34406 06/02/2003 9:28 PM
I have a 235 with a 216 intake and exhaust with no rings for the intake.
Can you use the 216 on a 235?
I am having a hard time putting the thing back to geather.
The top of the exhaust gaskets are loose, you can move them with your fingers after tighting them up.
This thing was working with just one little hiss before I took the I/E manifold off.
1951 1.5 ton 4400
#34407 06/02/2003 10:28 PM
You will have difficulty aligning the manifold without the rings. The ports on a 235 are bigger so it is really a good idea to use a 235 set. You should be able to get one cheaply if you post an ad in the swap meet.
Paint & Body Shop moderator
#34408 06/03/2003 12:10 AM
Get the 235 manifolds. The ports are bigger. You will also need to get the carb with them, mounting holes are different. Alignment rings are a must, too. They are bigger for the 235.
When I install the manifold gasket set, I use some ultra-copper sealant on the manifold side of the gaskets. Allow the sealant to cure for 24 hours before running the engine. This will usually eliminate any intake and exhaust leaks.
Fred
52 3600
69 C-10
#34409 06/03/2003 12:48 AM
Thanks Guys.
1951 1.5 ton 4400
