| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34402 06/01/2003 11:37 PM | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | Good eveing, Went to the part store well in fact called 7 and went to 3 to find a intake gasket for a Chevy 54 235. Does the 235 have an intake gasket? All I can find is the gasket for the exhaust and it comes with 7 holes. Thanks, Greg
1951 1.5 ton 4400 | | |
#34403 06/02/2003 12:19 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The intake gasket is combined with the exhaust gasket and it should be in three pieces. The round holes are the intake holes. You should have a little round collar for each intake hole. These are normally reused, not supplied with the gaskets. | | |
#34404 06/02/2003 12:34 AM | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | Thanks, how many ports are in the head? Does one port go for two cyls? Greg
#34405 06/02/2003 5:28 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I was referring to the gaskets between the intake/exhaust manifold assembly, and the head. There is a gasket that starts at either end, and one in the middle. There are three little rings and they fit into the head ports and into the intake manifold ports. | | |
#34406 06/02/2003 9:28 PM | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | I have a 235 with a 216 intake and exhaust with no rings for the intake. Can you use the 216 on a 235? I am having a hard time putting the thing back to geather. The top of the exhaust gaskets are loose, you can move them with your fingers after tighting them up. This thing was working with just one little hiss before I took the I/E manifold off.
#34407 06/02/2003 10:28 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You will have difficulty aligning the manifold without the rings. The ports on a 235 are bigger so it is really a good idea to use a 235 set. You should be able to get one cheaply if you post an ad in the swap meet.
#34408 06/03/2003 12:10 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Get the 235 manifolds. The ports are bigger. You will also need to get the carb with them, mounting holes are different. Alignment rings are a must, too. They are bigger for the 235.
When I install the manifold gasket set, I use some ultra-copper sealant on the manifold side of the gaskets. Allow the sealant to cure for 24 hours before running the engine. This will usually eliminate any intake and exhaust leaks.
Fred 52 3600 69 C-10
#34409 06/03/2003 12:48 AM | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 |
