1 members (Hotrod Lincoln), 153 guests, and 6 robots.
Topics128,268
Posts1,058,379
Members48,485
#343959 12/02/2007 7:15 PM
Are the rear bumpers on an AD pickup the same as on an AD suburban? Also the rear bumper on my 49 sub has a hole torched in the center of it by an unknown PO probably for a trailer hitch. Can this hole be repaired by welding in a patch with no adverse affect on the integrity of the bumper? If the bumpers are not the same I would like to rechrome the original after fixing the hole. Weeds
Weeds #344037 12/02/2007 11:58 PM
The Suburban (Panel Body) rear bumpers are the same as the front bumpers on all Advance-Design 1/2 ton trucks. The rear bumper brackets for Panel Body trucks are different from pickup trucks; and, the rear bumper brackets are different from the front bumper brackets.
Tim
tclederman #344111 12/03/2007 2:24 AM
A very common misconception is that the burb and panel rear bumpers are identical to the front bumpers.
I have done some research over the years and I found that the rear bumpers on the burbs & panels are NOT identical to the front bumpers.
They are rounded on the ends like a front bumper but when you lay an ORIGINAL burb or panel rear bumper next to a front bumper you can see that they do not have as much of an arc.
Close but no cigar.
Native49 #344113 12/03/2007 2:36 AM
Now I am really confused. Weeds
Weeds #344136 12/03/2007 3:25 AM
Would that mean that when using a front bumper on the rear of a panel body truck, the front bumper would not line up with the rear valance (or whatever it is called)?
What about part number 4300438 (from the Master Parts Catalog) for 1/2 ton panel body (single unit) trucks. Or, 4300437 for 1-ton panel body (single unit) trucks?
Native49 #344139 12/03/2007 3:27 AM
Close but no cigar.
problem with that kind of "research" is that those front and rear bumpers have the same part number in the master parts book [3700438], same with the 41-46 and 55-59 series panel/burb's, front and back are the same
Flxible #344806 12/05/2007 1:09 AM
Leo Offline
Moderator
Moderator
I think that there were two different types of rear bumpers. My 53 half ton panel had a heavy, thick rear bumper. It was quite different from the front. Maybe a PO put a bumper on from a big bolt? I acquired a front bumper off a pickup to replace it with. Weeds, I think you could likely repair the hole without weakening the bumper, it will still be better than the bumpers they make now-a-days.
Flxible #344811 12/05/2007 1:25 AM
OLTrucks
Unregistered
OLTrucks
Unregistered
I have found the same information in two dif master parts as Bill and both my burb bumpers front & rear lay right together.
Mike
