0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#34342 07/02/2004 7:54 PM
I need a little help. I haven't posted in a while, but now I'm beginning to restore my '51 1/2 ton. I want to pull the 3 speed trans, and I have followed the directions in the manual BUT it looks like there is not enough room to pull it back without hitting the universal ball. I slid it back on the prop shaft, but I'm not sure that it's all the way back. Can I persuade it a little with a block of wood and a hammer? How far should it go back? I do have it jacked up as far as it will go. How far out back does the transmission move to clear the clutch disc?
Any help would be great.
Mark
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
#34343 07/02/2004 9:25 PM
I had to persuade mine with a block and hammer. It's easier if you loosen the seal packing nut to help it slide. It should go back enough to separate the U-joint, then you can unbolt the frame crossmember and drop it down.
Paint & Body Shop moderator
#34344 07/02/2004 11:51 PM
Did you remove the crossmember for the very rear trans mount? If not you will have to remove it so the torque tube can be lowered some and them there will be room to get the trans out.
#34345 07/03/2004 1:29 AM
Thanks guys. Yes Jeff, I did remove the bracket so I guess that the wood and hammer are the next step. I did remove the nut and packing and it will move all way back, but not the ball. Bring on the BIG hammer. I will give it a try. Thanks again.
1951 Chevy 3100
