2 members (2-Ton, 1 invisible),
108
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34342 07/02/2004 7:54 PM | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | I need a little help. I haven't posted in a while, but now I'm beginning to restore my '51 1/2 ton. I want to pull the 3 speed trans, and I have followed the directions in the manual BUT it looks like there is not enough room to pull it back without hitting the universal ball. I slid it back on the prop shaft, but I'm not sure that it's all the way back. Can I persuade it a little with a block of wood and a hammer? How far should it go back? I do have it jacked up as far as it will go. How far out back does the transmission move to clear the clutch disc? Any help would be great.
Mark
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
#34343 07/02/2004 9:25 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I had to persuade mine with a block and hammer. It's easier if you loosen the seal packing nut to help it slide. It should go back enough to separate the U-joint, then you can unbolt the frame crossmember and drop it down.
#34344 07/02/2004 11:51 PM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Did you remove the crossmember for the very rear trans mount? If not you will have to remove it so the torque tube can be lowered some and them there will be room to get the trans out. | | |
#34345 07/03/2004 1:29 AM | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Thanks guys. Yes Jeff, I did remove the bracket so I guess that the wood and hammer are the next step. I did remove the nut and packing and it will move all way back, but not the ball. Bring on the BIG hammer. I will give it a try. Thanks again.
