5 members (78buckshot, KEVINSKI, GRNHydra, Gray_Ghost, Guitplayer), 189 guests, and 7 robots.
Topics128,078
Posts1,056,039
Members48,433
#34272 08/16/2003 2:39 PM
24601
Hey Gang,
A reader just asked me this: He has a freshly rebuilt 235 that's tight and the 6-volt starter won't crank it fast enough to start. I suggested he make sure all his adjustments (Timing, valves, crab, etc) are set correctly for a 235. Then what should he do?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
#34273 08/16/2003 2:44 PM
Is he sure that his electrical system is up to snuff ? Heavy battery cables, good grounds , etc.
Also, have him rotate the distributor while cranking to see if that makes a difference in spinning the engine. He may have the distributor in there one or two teeth off...
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#34274 08/16/2003 2:46 PM
24601
Thanks Bill -- Good advice. Hopefully, he'll see this.
What else?
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
#34275 08/16/2003 2:48 PM
Normally, I would not recommend this: he could power the starter (only) with a 12 volt source. A jumper cable would work: negative lead to the body-to-clutch-housing braided-ground-cable and the positive lead would have to be touched by hand to the positive post on the starter (disconnect the 6v positive lead from the starter). The ignition key would have to be turned on to provide power to the coil.
Be careful. If the starter does not turn easily, the engine might be too tight or the starter might be weak. I think that forcing 12v through the starter for long periods could damage it.
I trust that my suggestion above will be corrected and/or shot down by others with more expereience.
Tim
#34276 08/16/2003 3:08 PM
These trucks have been starting on 6 volts for many years. Putting 12 volts to that starter may get the truck to spin but when you put the truck back to 6 volts you still have the problem.
If you fix the problem in the first place, then you avoid having to go back and fix the problem..
Bill M
53 GMC Hydra-Matic
Home Page
#34277 08/16/2003 3:33 PM
Maybe the 6volt battery wasn't fully charged. If so, he should take timeout to charge it. Endless cranking on a fresh engine is not friendly to the cam. These are pretty simple so I'd first ensure gas to carb then spark at spark plug end. If that is OK, then go back to instructions for installing distributer.
40 Chevy 1/2 ton
#34278 08/16/2003 4:35 PM
I would go with the 12 volts to start it. The fresh rebuild will loosen up quick enough once its started. I had the same problem with a straight 8 Pontiac. New rings and fresh cylinders, the 6 volts was to slow to get it turning. After a break in run. The 6 volt had no problems. It may be best to replace the battery and use the factory cables. Just shut off all lights and radio. The extra voltage will help! Joe
#34279 08/16/2003 6:48 PM
I bought a rebuilt 1954 235 that was started up just long enough to ruin the crank,all but one piston and all the cylinders. The shims on the main berrings were not installed. The guy said it turned over hard.IF YOU HAVE A 1954 BLOCK YOU NEED TO SHIM.
#34280 08/16/2003 9:23 PM
To get the points set to TDC, get the #1 piston at TDC. Hook an ohm meter to the points insulated lug and to the ground (distributor housing). You should have a reading of 0 ohms or a few ohms. Turn the distributor body counter-clockwise until the reading on the meter shows that the circuit is open.snug the distributor hold down bolt and that part should be set to fire.
As the other guys have said, check the ground cable and you might even try a jumper cable ground from the block/bellhousing to the battery ground. Check the positive cable to make sure it is clean and tight.
One question,,,, how easy is the engine turned over by hand?
ALSO,, is there any metal glitter in the oil?
#34281 08/16/2003 11:48 PM
If he can't budge it by hand, with the fan belt, the engine should not be started because it is too tight.
1951 1 Ton Completed
#34282 08/16/2003 11:50 PM
sometimes one might by(incorrect rings in a box)install over size rings, this will make it hard to hand turn or start..don't ask me to go into it...fred
Redryder pix
My Hotrod
#34283 08/17/2003 6:28 PM
Oly Offline
If, as I read this, the 6 V won't start it and it is seeming to bind or drag, then my advise is to "STOP!!!" and tear the engine down and find the problem. Could be bearings, wrong or broken rings, not timed correctly or even wrong parts in the wrong engine. Suffice to say- Something is Wrong!!-. These engines will turn over and start very easy if assembled correctly. You don't need to use twelve volts or push/pull start them. Even Master Mechanics can make errors, but don't make the error of "forcing" the engine to run.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#34284 08/17/2003 9:56 PM
I agree, STOP !!!!!
If it cannot be turned by hand, I would suggest internal inspection of the engine to prevent possible costly damage
#34285 08/18/2003 12:33 AM
I'd agree, stop. But don't all 6-volt Stovebolts crank slowly like my old 235 did?
#34286 08/18/2003 12:52 AM
My 51 216 cranks over at a fairly good rate. I don't think a good six volt setup is a slow cranker.
#34287 08/18/2003 6:38 PM
As long as you use 4/0 battery cables the 6V starter spins just as fast as a 12V. A lot of people make the mistake of putting in 2 or 4 gauge battery cable intended for 12 volt systems. They drop the voltage too much.
Paint & Body Shop moderator
#34288 08/21/2003 3:09 AM
Junior Member
Junior Member
I just got a '54 235 back from being professionally rebuilt about 2 weeks ago. The guy who did it has done other 235's and he said in order to make the clearances right you have to shim them pretty tight. He said don't worry if it seems to be froze up when you are installing it; it's just the shims. Once you start it, they will seat and it will free up like normal. Sure enough, I couldn't turn it by hand and the starter had some trouble turning it over at first. Once it was started, everything was fine. Since the 1st start, the starter has spun it very nicely.
Also before starting it, find a long flat-head power screwdriver to spin the oil pump to get oil pressure. That will help lubricate the bearings and everything for the initial start.
Once you know the timing and everything is right (or at least close) and if 6 volts won't spin it, go ahead and jump the starter to 12. That will get it turning. It won't hurt the starter unless you just crank and crank and crank. Don't let it overheat. Once you get it started, it should free up and start easily on 6 volts if all your contacts are good and clean/tight!
Good luck!
Carl
#34289 08/21/2003 3:58 AM
Guy's there is just no good reason for an engine to be so tight that you can't turn it
If the spark plugs are our and it's been lubed you should be able to turn it.
If it takes a wrench that is much longer than the flywheel radius your gonna have at best an engine that doesn't run as long as it should.
Your engine builder should be cranking the engine as he or she assembles it
I had a gen drive bush tighten-up on an old engine
I was building once.If I'd not been moving the parts as I put them in it would have taken some time to find the problem
#34290 08/21/2003 6:26 AM
Pull the spark plugs and see how it turns over with no compression.
Brian D
#34291 08/21/2003 2:57 PM
I rebuilt my '54 235 several years ago, and it cranked right up, even though I left the main shims out. Engine ran 300 miles before seizing.
I'd be suspicous of any motor the starter wouldn't spin over.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
