2 members (Peggy M, Gdads51),
106
Mod | | | Forums66 Topics128,169 Posts1,057,043 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 2 New Guy | | New Guy Joined: Nov 2007 Posts: 2 | I am looking for info on what was used as a original front motor mount for a 1932 chevy 1 1/2 ton. Mine appears to just mount metal to metal with 2 spring loaded bolts. I have a rubber mount for a car but it would be too thick as the hand crank holes would not line up. It just doesn't seem right to not have some sort of cushion between the motor and frame. Any thoughts, comments, pictures would be greatly appreciated. Thanks Glenn | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I don't belive there is any mount. I cut a piece of inner tube and put between the frame and engine. (Made me feel better) | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | The front engine mount is what you have two spring loaded bolts and the two mounts at the clutch housing are solid mount "L" brackets. Chevy didn't start using a rubber front mount on the front until 1933.
34 & 35 trucks are the greatest
| | | | | Joined: Nov 2007 Posts: 2 New Guy | | New Guy Joined: Nov 2007 Posts: 2 | Thanks for the replies ,Thats what I thought I would do I have some thin rubber from a conveyer belt I planned to use. To make me feel better! | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | I don't think it will do much good for noise isolation as the rear mounts are solid. The 32 car mounting was all rubber you could adapt the front and rear mounts to your truck. The filling Station vendor has all the mounts.
