2 members (Hotrod Lincoln, 2-Ton), 149 guests, and 2 robots.
Topics128,087
Posts1,055,999
Members48,430
#34249 03/30/2004 9:02 PM
1 Offline
Ihave a 51 5 window, that I am hot rodding, 350, 700R4, 9" rearend. My question, is, I wish to use updated original springs with the springs under the axle ... what brackets/mounts can be used and is there a u-bolt setup with shock mount attatched that can be used...example s10 spring perches??
#34250 03/30/2004 10:04 PM
I have just done this on my 51, You can get spring pad kit with u-bolts and shock mounts from chevy duty or ccp, Kit is about eighty dollars or so. Old navy 51......................
#34251 03/31/2004 2:36 PM
1 Offline
Thanks, by the way, what is ccp??
#34252 04/01/2004 10:56 PM
The company is cpp, classic performance products or you can get it at chevy duty parts. cpp 1-800-522-5004. old navy51...................
