| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34249 03/30/2004 9:02 PM | Joined: Feb 2002 Posts: 22 Member | | Member Joined: Feb 2002 Posts: 22 | Ihave a 51 5 window, that I am hot rodding, 350, 700R4, 9" rearend. My question, is, I wish to use updated original springs with the springs under the axle ... what brackets/mounts can be used and is there a u-bolt setup with shock mount attatched that can be used...example s10 spring perches?? | | |
#34250 03/30/2004 10:04 PM | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I have just done this on my 51, You can get spring pad kit with u-bolts and shock mounts from chevy duty or ccp, Kit is about eighty dollars or so. Old navy 51...................... | | |
#34251 03/31/2004 2:36 PM | Joined: Feb 2002 Posts: 22 Member | | Member Joined: Feb 2002 Posts: 22 | Thanks, by the way, what is ccp?? | | |
#34252 04/01/2004 10:56 PM | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | The company is cpp, classic performance products or you can get it at chevy duty parts. cpp 1-800-522-5004. old navy51................... | | |
