| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 56 | Im working on a 63 4wd GMC 1/2 ton pickup and I need the inside hub nut on the front hub the one with the little pin that sticks out and goes into the locking ring and it has 4 indentations for the hub socket, my pin is broken off. Anyone know where to get one ordered on the net??? Is that the proper name "hub nut" ???  | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The '63 should have a Spicer 44 front end. You should be able to get those nuts from the flaps, as it's a standard part for that diff, same for all years/makes. Also, Spindle Nut would be a nore accurate term.
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 56 | Went by the flaps and they did not have it went by the local scrap yard and had one. Thanks for your help! | | |
