0 members (), 91 guests, and 4 robots.
Topics128,024
Posts1,055,393
Members48,422
#341875 11/27/2007 12:28 AM
Im working on a 63 4wd GMC 1/2 ton pickup and I need the inside hub nut on the front hub the one with the little pin that sticks out and goes into the locking ring and it has 4 indentations for the hub socket, my pin is broken off. Anyone know where to get one ordered on the net??? Is that the proper name "hub nut" ??? ohwell
heidel410 #341906 11/27/2007 1:44 AM
The '63 should have a Spicer 44 front end. You should be able to get those nuts from the flaps, as it's a standard part for that diff, same for all years/makes. Also, Spindle Nut would be a nore accurate term.
Bill Burmeister
LONGBOX55 #342267 11/28/2007 1:36 AM
Went by the flaps and they did not have it went by the local scrap yard and had one. Thanks for your help!
