1 members (baldeagle),
39
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34127 02/25/2005 5:27 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | So, I've been through adjusting my valves I dono how many times (.006 intake, .013 exhaust), and I still have one that ticks. My pushrods and rocker arm assemblies are new, as are the valves and springs (head was done a year ago). The other night, I reset them after I drove home from work. I started it and that one was ticking. Immediately, I checked the adjustment and they were all fine. I don't get it. What am I missing? :mad:
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#34128 02/26/2005 12:15 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Can you pinpoint which one is ticking? If you havn,t put the feeler gauge in the ones in the area of the noise. If it goes away with the gauge in it that is the one. Try adjusting it about .002 tighter than specs. It could have a little wear on the camshaft causeing the noise or a slight chance you have a car powerglide engine with hydraulic lifters.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#34129 02/26/2005 12:23 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | It sounds like you've done everything right. So now you have to double check some of the things your doing. Possible your adjusting the wrong valve? Recheck to make sure you have the intakes and exhaust matched up in the right position on each adjustment. Possible the set screw is coming loose for some reason on the one lifter your having trouble with. Check for bent push rod. Check for lack of oil on noisy lifter. Uh... I've run out of ideas. Cecil... | | |
#34130 02/26/2005 7:13 PM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Sounds like sticking hydraulic lifters. If it quiets down after it warms up, I would say it's no big deal. Mine does that too, but only when cold. When it warms up, it is quiet. Is that the case with you too?
If it bothers you that much, just try buying a new set of lifters. That might do the trick.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
#34131 02/27/2005 10:54 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you are setting the lash like that I'm assuming that you have solid lifters.
Are you sure that it is really a lifter ticking? Sometimes the fuel pump cam follower makes a noise that is very close to that, or you have some teeth on the timing gears that are chewed up. It could even be the points in the distributor or the rotor whacking a cap tower that is too high.
If it is really a valve, don't give in to the temptation to tighten it up beyond spec. You will greatly shorten the service life of the valve seats if you do. Slightly ticky valves are the correct setting on non-hydraulic lifters. They will not ruin anything by ticking.
My 261 has a pretty noisy valvtrain. I noticed a big differance by switching to a differant oil. I was using Valvoline 10W-40 and I switched to Chevron Delo 400 15W-40 and it has made a huge differance in valve train noise. Much quieter. It also smokes a bit less. I have leaky valve seals.
#34132 02/28/2005 2:46 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | Thanks for the ideas, guys. I guess I should have mentioned that the lifters are in fact solid. I haven't been able to pinpoint the exact lifter, but it sounds like it is either on the #5 or 6 cylinder. I don't think it will cause problems, but it is just real annoying. One of these nice spring days I'll recheck my adjustments, and I may look into that Delo oil. Thanks again!!
