| | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34123 05/25/2003 8:25 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Well, I should have known something would go wrong. I got my 261 in and fired up and the radiator decided to spring a bad leak. I guess I will have to get a new one, Jim Carter has them cheaper than re-cores.
I also hope I didn't fry a ring, I had cylinders 5 and 6 switched at the distributor and let it run for a few minutes that way, and was getting some blow-by, and then when I swapped them back it started smoking bad. I'm going to try to run some atf through there and unstick the rings, and change the oil, otherwise I will have a fogger for a while until I get this thing rebuilt.
Other than that it runs great, smooth and starts easily. The 6 volt starter really cranks well on 12 volts. The oil pressure is good, the rockers are oiling, and the vacuum is good. The alternator and short water pump shaft with foamoco pulley fit nicely.
#34124 05/26/2003 7:34 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Well, the smoke magically dissappeared after I let it cool off and started it again today, it must have had a stuck ring. Now I'm just waiting for a radiator.
