6 members (Hotrod Lincoln, 2-Ton, Wayne67vert, Pete1946, Otto Skorzeny, 1 invisible), 110 guests, and 1 robot.
Topics128,072
Posts1,055,903
Members48,429
#340493 11/23/2007 1:41 PM
Anybody installed these on their A.D.? Were they difficult to install or do they just bolt on?
Robert C.
I'm a Genius in the making.
1950 3600
I have never installed them,but I would like to have a set installed on my 55. They are welded in,and from what I have been able to find out it is quite a job.I know there are a couple of guys on this site who have installed them.I would like to find a set of bolt in latches simalar to the Bear Claws.It is just about impossible to get the original latches adjusted properly on my 55.
i installed them on my 52 but i installed them backwards. the bolt is on the door and the latch is in the door jamb. makes for a clean install, but i did mine that way because i was using door poppers. as far as putting them in the normal way, ive seen many threads about this and a search would reveal them.
ambear,that looks like a no weld installation.I am not interested in a power setup just a manual one.If I could get a kit that I could install without welding them in I just might give it a try.Any help or advice would be appteciated. Dale
For what it's worth, I just put a new stock latches in my '58 for about $60.00. Made a huge difference.
I installed Bear Claw latches on my 32 F@rd, 3 window coupe, and yes they were a Bear to install. They did work well after that.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
gtow69 #341835 11/26/2007 10:52 PM
Houston54
Unregistered
Houston54
Unregistered
