3 members (GMCJammer51, 68ironhead, Wayne67vert), 100 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#34021 01/14/2003 2:18 PM
Hello everyone! I just purchased a 1955 Chevrolet 3100 pickup. It currently has the 235cid with a foot pedal starter. I want to convert this to an ignition switch start system. Is there a newer version starter that will bolt directly into the place of the old starter? Thanks in advance for assistance.
Depewtee
1955 Chevrolet 3100 pickup 235cid
#34022 01/14/2003 5:38 PM
Welcome to the Stovebolt grin
First ones with a key and push-button came out in `55 smile
Save the original parts for someone who may want them cool
#34023 01/15/2003 8:42 AM
You can swap in a starter from a COE or car, or swap the flywheel for a '57 up and use a 12 volt solenoid starter, the teeth are differant.
Paint & Body Shop moderator
#34024 01/15/2003 3:29 PM
Don't forget that you need a different ign switch, one with a 'start' position. You'll have to run the wire from the "start" position to the solenoid on the starter. If your truck was originally 12 volts, you should be able to swap in a 12 volt solenoid starter from a '60-'62 truck with a 235, and not have to change the flywheel.
The 12 volt starters used 168 tooth ring gears, the 6 volt units used 139 tooth ring gears.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#34025 01/15/2003 4:25 PM
Oh my goodness,
Who'd ever consider giving up one of the neatest features of an old truck. My truck would jump off the nearest cliff if I even considered it eek
Craig
#34026 01/15/2003 8:12 PM
Not only did my PO yank out the foot switch he installed the cheapo, generic keyswitch. Bringing it back and buying the proper keyswitch is going to be expensive. Don't do it.
54 3100 with 235
62 flatbed dump C60 with 261
