| | | Forums66 Topics128,041 Posts1,055,490 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34021 01/14/2003 2:18 PM | Joined: Jan 2003 Posts: 8 Member | | Member Joined: Jan 2003 Posts: 8 | Hello everyone! I just purchased a 1955 Chevrolet 3100 pickup. It currently has the 235cid with a foot pedal starter. I want to convert this to an ignition switch start system. Is there a newer version starter that will bolt directly into the place of the old starter? Thanks in advance for assistance.
Depewtee 1955 Chevrolet 3100 pickup 235cid | | |
#34022 01/14/2003 5:38 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Welcome to the Stovebolt First ones with a key and push-button came out in `55 - Save the original parts for someone who may want them
#34023 01/15/2003 8:42 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can swap in a starter from a COE or car, or swap the flywheel for a '57 up and use a 12 volt solenoid starter, the teeth are differant.
#34024 01/15/2003 3:29 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Don't forget that you need a different ign switch, one with a 'start' position. You'll have to run the wire from the "start" position to the solenoid on the starter. If your truck was originally 12 volts, you should be able to swap in a 12 volt solenoid starter from a '60-'62 truck with a 235, and not have to change the flywheel. The 12 volt starters used 168 tooth ring gears, the 6 volt units used 139 tooth ring gears.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#34025 01/15/2003 4:25 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Oh my goodness, Who'd ever consider giving up one of the neatest features of an old truck. My truck would jump off the nearest cliff if I even considered it
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#34026 01/15/2003 8:12 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Not only did my PO yank out the foot switch he installed the cheapo, generic keyswitch. Bringing it back and buying the proper keyswitch is going to be expensive. Don't do it.
54 3100 with 235 62 flatbed dump C60 with 261
