| | | Forums66 Topics128,178 Posts1,057,063 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33990 03/10/2004 4:06 PM | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | I have finally gotten some pictures taken of my truck. A long project nearing completion. You will notice there are no pictures taken from the front. I have still not finished restoring the grill, so there is a big gaping hole in the front that I avoided taking a picture of. You can see the before pictures in the gallery. Stevejumpr\'s 55 1st Series 3/4 ton
Steve 55 1st Series 3/4 ton
#33991 03/10/2004 4:35 PM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | The pictures are great but you should see the truck in person like I just did! It's even better in person. Great job Steve! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#33992 03/10/2004 4:38 PM | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | Very nice job ob the truck/Restoration! I like the wood, and the bowtie stepping plates, those are neat! Kepp up the good work, and good luck with your project!
- ChevyToughRebel
- Shane (ChevyToughRebel) 2 Trucks; -1955 3/4 Ton Chevy -1979 3/4 Ton Custom Deluxe 20 4x4 1955 Second Series 3600 GED = Git Er Done
#33993 03/10/2004 4:46 PM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Great work Steve. I too like the wood running boards. Goes great with the forest green paint. What a joy! | | |
#33994 03/10/2004 4:59 PM | Joined: Feb 2000 Posts: 120 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 120 | 1954 44001954 3800Jim D. '41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck '54 Chevy 3800 Dump........New Truck! '54 Chevy 4400 flatbed/dump, Gone to my brother-in-law '13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles '01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
#33995 03/10/2004 8:53 PM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | very nice, my taint gonna b so purdy tho! But I am going to do up a nice flatbed on it.
Great job. | | |
#33996 03/10/2004 9:56 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Nice woodwork Steve. Clean engine compartment. I really like your choice of color. More pictures please.  | | |
#33997 03/11/2004 1:46 AM | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | Thanks for all the kind words. I drove it to work for the first time today and had to take the boss for a spin (her first ride in an AD pickup!) I will post more pictures as other small projects finish up (grill, interior, etc...) It is just nice to be on the road with it again. As for the "niceness" of the project. I did not plan it that way, I just became overcome by events as we say and before I knew it I had a bare frame and all went from there. Thanks again. More to come.... P.S. I think you can almost make out Wally's office from one of the pictures  Kind of nice working so close to another stovebolter!
#33998 03/11/2004 3:01 AM | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | What color green is that? Very pretty.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#33999 03/11/2004 3:26 AM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | stevejumpr, that is a nice ride. The wooden running boards look really great. That bed and the color is cool also... Great job. What kind of wood did you use? Also, what did you treat it with, it looks shiny... -W | | |
#34000 03/11/2004 2:00 PM | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | The paint color is the original Juniper Green and the front bumper and soon to be finished grill will be original Bombay Ivory. A local paint shop had some 50's era paint code books, found the old formulas and mixed me up the colors. I had a local body shop do most of the body work and the final painting. I did the block/finsh sanding myself to help lower the final costs.
The wood for the bed/running boards is either Fir or Pine (we could not figure out which) that we bought directly from an Amish run sawmill North of St. Ignatius, MT. We bought rough cut 2x12s as the base material and spent the day planing them and jointing then routing the edges. The bed boards were beveled on the edges. I used the original running boards (they were almost completely rusted through) to make a template for the wooden running boards, then cut and individually shaped them to fit snug against the front fenders.
Everything is finished with a cherry stain to help match with the green truck better and then top coated with three coats of Man-o-War Satin Spar Varnish (I did not want the high gloss stuff). The bottom of the boards are all sealed with some spray on rubber undercoating picked up at the local auto store.
If I had to do it over again, I would use some clear fiberglass and epoxy on the running boards to give them a harder surface as they are likely to get dinged up pretty well over the years. The step plates are a must to try and protect the wood where you can.
Thanks again for the compliments.
#34001 03/12/2004 7:54 PM | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | Great Looking Truck. Very good craftsmanship. I love it.
Professional Novice
#34002 03/14/2004 7:04 PM | | Anonymous Unregistered | | Anonymous Unregistered | | | |
