Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (2-Ton, Peggy M, Youngin' Tut 59, Jon G), 36 guests, and 7 robots.
Topics128,010
Posts1,055,303
Members48,419
#339665 11/21/2007 2:29 AM
1 Offline
i was just wondering if you guys had any suggestions as to getting a higher ride hight on a 49 1/2,i want my truck to be able to go down the dirt roads at my cabin without worring about every little bump or rock.is thier a easy way other than a fram swap liking getting bigger leaf springs to raise the truck?i was thinking of like a 29-31 inch or metric size in the same area?
Larger tires would be the best way to increase the ground clearance. heavier springs will not really raise it up much, and will make the ride much stiffer. A 235/85/16 is roughly 31" in diameter, or a 245/75/16 (more common) which comes out to about a 30", would help with ground clearance. You could consider re-arched springs up front and a spring over axle conversion in the rear to get some more hight without doing anything too drastic.
Bill Burmeister
LONGBOX55 #339702 11/21/2007 4:20 AM
I did a combination of a body lift(4"),a suspension lift(leafs over axles),and 35"tires on my 73Jimmy.
Lothar
