3 members (tclederman, Otto Skorzeny, 1 invisible), 116 guests, and 0 robots.
Topics128,076
Posts1,055,920
Members48,429
#339589 11/21/2007 12:09 AM
Apprentice
Apprentice
last night i was pulling the engine out of my 52 gmc one ton dually. with the engine bolted to the transmission, i was having problems getting it out of the front end.I did have an engine hoist. the crossmember where the transmission is bolted to was right in the way. I had to cut it out to get the engine out...I know...I should have removed the cab...but what did i do wrong. how do you guys get the darn thing out without a torch.
shorthood2006 #339597 11/21/2007 12:22 AM
Remove the transmission, all of 4 bolts right?
If it is of any use, I have that crossmember for sale, removed by removing the rivets (no torch). I believe it is the same, mine from a 48 Chevy 2 ton?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #339657 11/21/2007 2:11 AM
i took engine and transmission out of a 1 ton don't recall cutting the crossmember. what i forgot to remove was the groundstrap. i do remember the results of that
