5 members (Peggy M, Hotrod Lincoln, Gdads51, mick53, 2-Ton), 132 guests, and 4 robots.
Topics128,165
Posts1,056,989
Members48,458
I have radio delete plates from a '54 - '55 Chevy and from a '54 -'55 GMC. Both plates look identical, except the GMC plate does not have the Chevy bowtie emblem.
When I flip the radio delete plates over, the Chevy plate has two metal clips that hold the plate into the dash. The GMC plate has two metal tabs, with screws,fender washers and nuts that hold the GMC radio delete plate to the dash. I know the Chevy clips are original, but GMC configuration also looks like it could be from the factory.
Where there differences, between Chevy and GMC in the way these plates were insatlled?
I have seen numerous radio delete plates for the 54 - 55 Chevy and they have the clips. This is the first radio delete plate that I saw for a GMC.
The dash in the GMCs was completely different in those years so it would stand to reason, the delete plates would be too.
I fully understand the differencs between the Chevy and GMC dashes. The radio delete plates appear to be among the few parts of the dash that are interchangable.
Both the Chevy and the GMC plates, that I have, are the same size and shape. The only difference is the way that these two plates were mounted to the dash.
btt
Moderated by  ndkid275, Phak1
