| | | Forums66 Topics128,272 Posts1,058,316 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | To begin with, this may not be the right forum. If not, I apologize. My speedometer was working. It has since stopped. New cable, so I don't think that is the issue. I do remember that a few eeks back, I was drilling a hole in the dash larger for a different size cable. I was near to the dash cluster and using an electric drill. As I drilled, the speedometer registered 30 mph or so. Is it possible that I 'degauzed" the magnets in the speedometer? If I messed it up, can I fix it, or should I just get another 56 Speedometer? Help! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | doubt there's a connection, the speedo was registering the vibration of the drill, failure is purely coincidental . . . disconnect the cable at the speedo, drive the truck and see if the cable turns, if it doesn't, check the trans gear, if it does, pull the speedo and bench check it
Bill | | |
