| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33853 07/10/2003 12:21 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | I noticed while checking where the oil line goes through the block that feeds the rockers..there are othere holes on each side where this line goes through...what are they for?
1946 chevy 1/2 ton panel 1937 ford coupe | | |
#33854 07/10/2003 12:53 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | The one forward of the oil line is for the return line on the exterior oil filter. If no filter the hole just has a pipe plug in it. The hole towards the rear is where the fitting for the oil pressure guage line goes. If running a filter,there is a brass tee there. No filter, a brass elbow for the oil pressure guage. | | |
#33855 07/10/2003 3:25 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | I don't know..brjr51
I don't see any threads on the inside of these hole's in the block?
#33856 07/10/2003 3:48 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | I hope were talk'n about the same side (pushrod) side..I believe these hole's are covered by the side pan (pushrod pan)
#33857 07/13/2003 2:20 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Sorry, me bad. I was thinking you were talking about the other side of the block. If you mean under the side cover, I believe those holes are there for the oil to drain back to the pan. | | |
