3 members (baldeagle, cmayna, Gray_Ghost), 61 guests, and 5 robots.
Topics128,017
Posts1,055,338
Members48,419
#33785 02/23/2003 1:40 AM
Apprentice
Apprentice
I was just double checking to make sure I am reading the axle donor tech page right. I have a 1950. I want to swap out the rear axle. It looks like I can go with a 68-72 Nova, 67-69 Camaro, 64-67 Chevelle. Is this correct? Which one would be best? If I pick it out of a junkyard should I get it rebuilt (I guess this depends on the condition, Huh)? Anyway, I plan on putting in a 350 and an auto trans. grin
Everything you know is wrong.
#33786 02/23/2003 1:54 AM
look at the tech section on our site...Fred
Redryder pix
My Hotrod
#33787 02/23/2003 3:00 AM
Apprentice
Apprentice
Thats what I checked. I wanted to make sure I was looking for the correct ones. More than that, I wanted to find out what others are using and what to watch out for...Sherod
#33788 02/23/2003 3:17 AM
I have a 52 half ton that is now in the shop to change out the drive train, going with 85 blazer rear end so I can keep the 6 lugs, will have 2:73 rear end which most feel is not tall enough, will have 88 s10 5 speed, do not know how it will work, should be ready in a few days, will keep the 235, and it will still look stock,will let you know in a few days how I like it....Fred
Redryder pix
My Hotrod
