| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's not a fuel filter, it's an oil filter! Looks like a po has rigged something up to make a makeshift filter for the fuel. The correct filter would be the glass bowl type that mounts inline, usually on the inlet of the carb.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | The mounting was not made very professional so I thought that it was not correct/original but there was definitely fuel going through.
'59 Apache '67 Mustang
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's the first time I've ever seen that! At least you won't have to go looking for an oil filter canister when you decide to filter your oil.
| | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Wow - that's bizarre. A remote oil filter canister used as a fuel filter. I wonder if that was done for some purpose or the installer just didn't know any better.
| | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | The previous owner had 2 extra gas tanks in a bad condition. Maybe it was necessary to use that "oversized" fuel filter bacause of rust ;-) Thanks for your help!
