8 members (Hotrod Lincoln, carbking, tclederman, Bill Hanlon, 49choptop, Guitplayer, John L., Otto Skorzeny), 125 guests, and 4 robots.
Topics128,042
Posts1,055,501
Members48,424
#337282 11/14/2007 7:28 PM
My Fuel Filter was mounted to the right inner fender.
Is that the correct location?
[IMG]http://img86.imageshack.us/img86/3740/0000090fl4.th.jpg[/IMG]
'59 Apache
'67 Mustang
That's not a fuel filter, it's an oil filter! Looks like a po has rigged something up to make a makeshift filter for the fuel. The correct filter would be the glass bowl type that mounts inline, usually on the inlet of the carb.
Bill Burmeister
Oil filter?
1959 Apache?
The mounting was not made very professional so I thought that it was not correct/original but there was definitely fuel going through.
'59 Apache
'67 Mustang
Ex Hall Monitor
Ex Hall Monitor
That's the first time I've ever seen that! At least you won't have to go looking for an oil filter canister when you decide to filter your oil. grin
Wow - that's bizarre.
A remote oil filter canister used as a fuel filter.
I wonder if that was done for some purpose or the installer just didn't know any better.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
The previous owner had 2 extra gas tanks in a bad condition. Maybe it was necessary to use that "oversized" fuel filter bacause of rust ;-)
Thanks for your help!
'59 Apache
'67 Mustang
