2 members (KEVINSKI, 1955 1 Series), 237 guests, and 2 robots.
Topics128,196
Posts1,057,395
Members48,471
I'm trying to find draglites or something for my truck. It's got a 5x5 patern on it but draglites only come 5x4.5 or 5x4.75. I can run an adapter on the rear but for the front I can't.
Do any of the car rotors work? I assume I would need a different bearing?
Thanks in advance.
1963 Chevy P/U: Forged LS1/4L80E swap and big hit of N20 coming
1973 Camaro: Low compression solid roller LS1 with PT91 turbo Built for the Silver State classic
1967 Convert Continental: Stock Cruiser
I have used Chevelle rotors on a '54 spindle, don't know if the '63 is same but I'd say try it and see. I used an extra bearing race for a spacer but otherwise unchanged. This was done over 20 years ago and no problems since.
The truck spindls are larger than than passenger. I don't think there's any bearing that will aloow a car spindle to fit without sacrificing strength. Perhaps you could have the spndles redrilled for the 5x4.75 pattern? I'd suggest the same on the rear, rather than adapters, especially if the truck is going to hit the track. I don't beleive that adapters are legal for use for racing, and I wouldn't trust them, seen too many failures.
Bill Burmeister
