2 members (JoergK., TUTS 59),
120
Mod | | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 97 | I'm trying to find draglites or something for my truck. It's got a 5x5 patern on it but draglites only come 5x4.5 or 5x4.75. I can run an adapter on the rear but for the front I can't.
Do any of the car rotors work? I assume I would need a different bearing?
Thanks in advance.
1963 Chevy P/U: Forged LS1/4L80E swap and big hit of N20 coming 1973 Camaro: Low compression solid roller LS1 with PT91 turbo Built for the Silver State classic 1967 Convert Continental: Stock Cruiser
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I have used Chevelle rotors on a '54 spindle, don't know if the '63 is same but I'd say try it and see. I used an extra bearing race for a spacer but otherwise unchanged. This was done over 20 years ago and no problems since. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The truck spindls are larger than than passenger. I don't think there's any bearing that will aloow a car spindle to fit without sacrificing strength. Perhaps you could have the spndles redrilled for the 5x4.75 pattern? I'd suggest the same on the rear, rather than adapters, especially if the truck is going to hit the track. I don't beleive that adapters are legal for use for racing, and I wouldn't trust them, seen too many failures.
Bill Burmeister | | |
