1 members (Forty9),
176
0
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | Hi, When I got my Chevy c10 it had some different lights added on the back with a flat bed. I now baught the full bed, put it on, I have been trying to get the wiring worked out. I saw on my friends truck (he has a 65 c10 also) that there are three wires running back. I am wondering are there two grounds and one power or two power and one ground. I am thinking possibly there are two power and one ground that goes from the left side light to the right side light. Any help would be great, a pic would be great also. thanks.
[url=http://www.stovebolt.com/gallery/dennis_nathan_1965.html]1965 Chevrolet C-10[url]
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I don't have a wiring diagram for your truck but I doubt if any of those wires is a ground. The usual 3-wire set-up is: 1. tail lights (connected to the light switch) 2. left blinker/stop light 3. right blinker/stop light
The ground for all these is the bulb housings which are grounded to the bed of the truck.
These can be easily identified with a 12 volt trouble light you can buy at any parts house. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Waldo is correct. You can buy flat 3or 4 wire cable used for trailers at any parts store. It works good for that. Brown is tail/marker lights. Yellow is left turn. Green is right turn. 4 wire has a white wire that can be used for a ground or back up lights. Be shure you have a ground wire from the frame to the bed. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
