2 members (TexasJim50, Gdads51), 108 guests, and 0 robots.
Topics128,049
Posts1,055,740
#336101 11/11/2007 9:22 PM
Any opinions on how well corvette suspensions work for the AD chassis.
Coupe #336114 11/11/2007 10:23 PM
What year Corvette?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I have the Flat out engineering kit with 1996 c-4 stuff and although i cant drive on it yet it seems to work great. the coilovers work nice and it's a little different from all the mustang stuff you see. i have some pictures on my webshots if you want to see. just look in my sig
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
Its hard to say. Are you running just the front, or the front and rear?
That C4 suspension stuff is about as good as a front motor and transmission with rear drive gets, but remember it was engineered for a very low car with a wheelbase under 100 inches and for some pretty wide tires, 255s being the narrowest I believe were ever put on it. Your choice of coilovers might be the determining factor. The C4 used a fiberglass leaf spring originally that was pretty stiff and contributed a lot to the handling of the car.
If the rest of the truck is executed as a sports car with low center of gravity handling could be fantastic. My daily driver is a C4 Corvette with the stiffer suspension package and fancy shocks. It rides rougher than some trucks but handles like nothing else I've ever driven.
The links not working brent563100 ohwell Ed
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
http://www.cardomain.com/ride/2412127
Here try this one.
Pics
Anything will work with a torch and a welder. I have C4 IRS / IFS handy for one of my projects. I have also looked into a Jag IRS from the local salvage yard. All will require a bit of fabrication.
And IFS and/or IRS will improve the ride quality of an AD but you can't expect a vehicle with a much higher center of gravity to handle as good as a Vette or Jag XK, but handling will be improved over stock. Wide tires also are a great help in the handling department.
However I plan on lowering my truck a few inches to help with the center of gravity. I would think those doing an IFS/IRS would be doing something similar.
