7 members (GMCJammer51, Youngin' Tut 59, Tim Canfield, jmoore, 3B, 2 invisible), 111 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
#332001 11/02/2007 2:29 PM
Apprentice
Apprentice
I need some input, I have a 1951 chevy 3100. I plan on running a 388 SBC with a 700r4 transmission. I will also have a TCI front suspension on the front. I have been considering boxing in the frame, is this neccessary, the frame appears to be somewhat weak. I have the material to box in the frome from front to rear. Anyone have any input on this? thanks
Tony Jacques
Considering you're running a 388 I assume you might be "getting it on" so to speak. Also considering you have the steel and the welder and the ability to weld, I would say, it you have the time, go for it. Besides it sure looks good.
~Jim
AS stated, if you plan on getting it on, you absolutely have to strengthen the frame. It won't break, but you will twist it with the torque you'll be putting down. p.s. how did you get 388 c.i.? I thought the stroker 350 was a 383 ?
Tim K #332092 11/02/2007 6:05 PM
Didn't Rambler make a 388? grin
~Jim
Apprentice
Apprentice
Tim K, 350 block bored 60 with a 400 crankshaft is a 388, bored 30, 383
Tony Jacques
Just posted this on another topic. I just bought "How to Build Hot Rod Chassis" by Tex Smith, $23.
Chevy truck frames are basically same deal (in fact he covers putting a front clip on one) as rest of the stuff he covers. See that for more info.
R-Bo
1966 GMC 305V6 in the family
R-Bo #336627 11/13/2007 3:26 AM
The stock 3100 frame is 10 gauge. contact your local sheet metal guy, and have him sheer off a few strips. The fire up the welder.......a few hours later, fire up the grinder.......a few hours later add paint.
I am in the same boat with a BB Olds.
RT1 Offline
That TCI frontend should have some metal to box in the frame where IT mounts. Boxing the frame can be a bear you have to mount all your tubing on the outside of IT.
I have the frame on my 40 ford boxed. IT does look nice when finished.
RT1 #336903 11/13/2007 7:58 PM
I would think you could run tubing inside the box if you planned it out in advance and left an opening where needed.
~Jim
tjacques #488647 01/01/2009 10:11 AM
waveG'Day Tony,
It is law here to box ALL of our chassis rails as part of registration.
The hardest part is making sure that you plan well ahead to ensure that you have all your fuel/brake lines, electrical wiring and captive bolts in place BEFORE boxing the chassis rails.
It's really hard to get all this sorted once the rails are boxed.
Once that is done, the boxing is quite a straight forward process.
A real handy tip is to use strips of cardboard cut out to the exact shape of the frame rail, trace them onto your sheet steel and then cut out the boxing plates to the right shape.
Good luck....Doc.
"It's not a wreck......It's a natural resource!"
Quote-Doc Bob circa 2006
DOCS CLASSIC GARAGE
Specializing in Hot Rods,
Customs & Street Machines.
My pictures at..........
1936 Chev 1/2-Ton Holden Body
confused? http://www.koalanet.com.au/australian-slang.html
doc bob #488653 01/01/2009 10:43 AM
Because of the weight of the motor and the power. It WILL twist the frame the first time you punch it. If you box YOU MUST bod From the front of the arm Mounting point to the rear leaf Mounts. You will also, want a cross over bracing. Like an X frame.
Depending when the book was made. The tecnologies today require the X Frame support. It is by far safer. I do not recomend installing any wires or tubing like brake lines inside your future inclosed frame as stated in another post. If there is leaks or a short in the wires. You will have a hard time. Plus if they are installed before you box the frame. YOU may very well have issues with the heat doing damage to the wires etc.
Good luck
Poets Seat Auto
Appraisals, Parts, Service
Past: General Motor's Master Technician
Member: Northeast Chevy/GMC Truck Club
Phone Number: 413.774.5856
Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
doc bob #488716 01/01/2009 4:44 PM
H Online: Content
Building a solid box just adds more weight than is necessary. The same strengthening effect can be had by cutting large ovals into the plates you add before they are welded in, leaving an inch or so on the top and bottom to add the necessary stiffening. it's a trick I learned long ago when beefing up dirt tracker frames. The box section adds the strength, and the cutouts allow weight to be concentrated where it's needed instead of just making the thing a lead sled. To make the cutouts uniform, use a large hole saw to form the ends of the slot, and join them with a straight cut with a sawzall.
The cutouts also solve the problem of making the channel area inaccessible for tubes, etc.
Jerry has just the same thought i have. box it w/ holes as the mid section is from the factory. in other words keep the structural integrity of the box but have the steel company or you plasma cut holes triangles or ovals in the box before you weld it all up. you would have access inside the box for wiring, fuel and brake lines. some steel shops can do this work for you as in small job production.
my fairly local one does big and small jobs. and in this economy many more may also job it for you. smile
http://www.sk-steel.com/
Jim & Caroline
The small block weighs less than the original L6.
