0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 47 | Any opinions on how well corvette suspensions work for the AD chassis. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | | | | | | Joined: Sep 2005 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 96 | I have the Flat out engineering kit with 1996 c-4 stuff and although i cant drive on it yet it seems to work great. the coilovers work nice and it's a little different from all the mustang stuff you see. i have some pictures on my webshots if you want to see. just look in my sig | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its hard to say. Are you running just the front, or the front and rear?
That C4 suspension stuff is about as good as a front motor and transmission with rear drive gets, but remember it was engineered for a very low car with a wheelbase under 100 inches and for some pretty wide tires, 255s being the narrowest I believe were ever put on it. Your choice of coilovers might be the determining factor. The C4 used a fiberglass leaf spring originally that was pretty stiff and contributed a lot to the handling of the car.
If the rest of the truck is executed as a sports car with low center of gravity handling could be fantastic. My daily driver is a C4 Corvette with the stiffer suspension package and fancy shocks. It rides rougher than some trucks but handles like nothing else I've ever driven.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | i have some pictures on my webshots if you want to see. just look in my sig The links not working brent563100  Ed | | | | | Joined: Sep 2005 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 96 | | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Anything will work with a torch and a welder. I have C4 IRS / IFS handy for one of my projects. I have also looked into a Jag IRS from the local salvage yard. All will require a bit of fabrication.
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | And IFS and/or IRS will improve the ride quality of an AD but you can't expect a vehicle with a much higher center of gravity to handle as good as a Vette or Jag XK, but handling will be improved over stock. Wide tires also are a great help in the handling department.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | However I plan on lowering my truck a few inches to help with the center of gravity. I would think those doing an IFS/IRS would be doing something similar.
