2 members (Guitplayer, Achipmunk), 61 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
Hello all, I was wondering where I should install the rear shocks mounting bar, how far from the rear end it should be?
Thanks James
If it was easy, everybody would be doing it.
Somebody out there has had to install a shock mounting bar, cross member for the rear end of a truck. I am just looking for some ideas.
Thanks James
What year and size truck are you installing it on? Most older GMs (pre-73 w/staggared shocks) the upper shock mounts are placed just aft of the axle centerline, basicly flush to the axle housing cover face. Shocks themselves are mounted at an approximate 45 degree angle from verticle, with the uppers pointed inboard.
Bill Burmeister
The truck is a 41 3/4 ton long bed, I have a GM 10 bolt rear end.
James B:
Mine is a 51 3/4 ton with a 10 bolt camaro but you can check my WebShots out. The physics of the placement should carry through.
http://good-times.webshots.com/photo/2304201370099708909eQJBQE
~Jim
Thanks BIG CHEVY
What is the difference between the shocks at 45 degrees from vertical & straight up & down like Big Chevy's? and what is the diameter of that rear shocks mounting bar Big Chevy?
Thanks James
James:
the bar is 1.75 soft steel and the shocks are at 80 degrees. You just don't want them to be at 90 degrees. You have to plan ahead as to how you will route your exhaust pipes. Be sure to leave yourself enough room to get back through there.
~Jim
Thanks again Big Chevy
James
