0 members (),
171
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hey guys,
My 235 now has about 140 miles on it. Its running very well, but still smoking somewhat. I'm driving it around town, cruising at about 2000 RPM and staying off the interstate. Anything I can do to help the plasma-moly rings seat properly?
I changed the oil this weekend. Didn't see any metal. But when I emptied the drain pan, there was a little bit of moisture in the oil, like some antifreeze had gotten into the crankcase. It was only maybe an ounce or two... Should I be concerned? Retorque the head gasket or drive it or what? Engine runs cool and has 30 PSI oil pressure hot.
thanks chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | My 235 use to do the same thing. I figured it was moisture "condensation" from the road draft tube or the breather on the top of the valve cover.
Joe
#3352 09/29/2003 10:34 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | It won`t hurt to re-torque the head. The engine should be ran at varying rpm throughout the drives you take it on. The first 283 I rebuilt in highschool smoked for a long time, not much but some. I ran the engine hard for about three years. I stopped in to a store to get something to drink and I was thinking I should check my oil,,,,, I started talking to a real nice looking sweetheart and forgot all about the oil. About three miles or so out of town (115mph) I heard a faint rattle noise. Looked at the oil gauge and it was at "ZERO"  I stopped, turned around and headed back to town for oil but the damage was done
#3353 09/29/2003 11:48 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | OK, I figure I'll torque the bolts I can get to with the VC on, and if any of 'em budge I'll pull the VC and do 'em all. I guess I should be watching my water level, eh?
The motor seems to smoke at idle, out of both sides but more on driver's side. When I rev it up and let off I get a good puff of smoke, then it fades. While I had it apart I changed the valvestem seals, and I pulled and cleaned the valves. Only have 12K miles on valves and guides. Should I accellerate hard or easy as I go thru 1st and 2nd? Let the engine slow the car down to work rings?
thanks
chip
#3354 09/30/2003 12:00 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Don't put any strain on the motor but run it through varying RPM's throughout each ride. After every so many miles you can increase the top rpm.
I am keeping everything crossed at once on this one.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Apr 2000 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 71 | The smoking sounds like valve guides worn. Put some umbrella (**** ) style seals, on the valves to help stop that problem. If you ever do another ring job, use only plain steel rings. I know everyone has an idea about that, but I never had a motor use oil, that had them in it. I use them in my racing motors and run them full rpms, after about 20 minutes breakin time. There is an old time remedy to seat the rings, but I won't suggest it until you do the valve seals, first. | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Chip, are you sure that's water and not gas? Could you have some blow-by from a ring that hasn't seated? I assume you checked compression repeatedly before firing it up, but have you done that recently? | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Coolant leak - Did you put a stop leak, such as aluma-seal in the system? I've learned to do this on any new engine. Also not to put in antifreeze until I'm sure there are no leaks. Seating rings - Get up to about 40 mph, then back off to about 20, and accelerate again. Up and down several times, full throttle to closed. This will help seat the rings. With stock rings this only takes a few times to seat, I don't know about your super-duper rings. Hope you have your lucky rabbits foot in your pocket this time.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Fred is right, ring manfacturers recomend driving the vehicle immediately ,putting a load on the engine.I am no pro engine builder,but the several car/truck engines and many motor cycle engines I rebuilt, never smoked using the above technique, and using regular motor oil for the break in.The 261 I did a few years ago,has moly faced rings, the advantage of moly is supposed to be a fast break in and good ring seal.This engine never smoked even when first started.I always use umbrella seals on my 235/261 engines, the exact same ones used for replacements on small block V-8 Chevys.Your problem my be seals however if you are using only the o ring type. | | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Thanks for the suggestions. The strange thing is that I didn't notice the engine smoking like this on the last build that ran 100 miles. I didn't do anything to the head this time except clean it up and install new o-ring valvestem seals.
I'm running castrol 10W30. I'm going to retorque the head and keep an eye on the oil and water levels. I'll try the getting on/off the engine as suggested to seat rings. I'll post back and give an update.
thanks!
chip
#3360 09/30/2003 11:28 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Was on the south side of town today and stopped by my machinist. I asked him the same ques I posted above and this is what he said;
The moly rings shouldn't be smoking. The total seal rings seal off so good, the engine is sucking oil past the intake guides. He gave me 6 positive style seals and told me to change the o-rings out for them on the intakes. Hopefully they'll fit.
On the possible coolant seepage, he told me to re-torque the gasket while I had the valvetrain apart. He said I could use some "ceramic seal" in the cooling system to seal up any small leaks. The stuff forms a coating on the water jackets and seals off. Run it with straight water for two days, then drain system and let dry for a day, then go back with antifreeze. Should I try the ceramic seal or just re-torque?
thanks
chip
#3361 10/01/2003 12:33 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Chip,if you're running a higher lift than stock cam,it's a possibility the clearance between the top of the valve guide and valve spring retainer at maximum lift isn't enought to clear an umbrella type seal.At least it wasn't on my engines, I had to reduce the guide height by a 1/16 inch. Did it of course while the engine was diassembled. | | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | The shop apologised for not catching this technical tid-bit. I had been running umbrella style seals with the clifford 260 cam, which has a higher lift than the M4F i'm running now. He gave me some positive type to use. However, the old umbrella seals were used with the stock retainers, I have a set of comp cams retainers now, so I hope I have enough room between retainer and guide for this type of seal.
For clearance, do I need just a little wider gap at full lift between retainer and guide than the thickness of the top of the seal?
thanks
chip
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I installed umbrella seals on the intake valves. Its still smoking, but not quite as bad. I've been told its worse on the driver's side. Both pipes have oily residue in them.
Would the rings take longer to seat if the shop used too-fine a finish hone? In general, do rings in most engines eventually seat?
Did a compression test: All 6 holes were between 120-130 PSI.
chip
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Curious,,, how much vacuum is this engine pulling?
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | At idle the engine is pulling about 15 or 16 inches of vacuum. About 20 on fast idle, I assume that or more while at cruising speed. The last engine pulled comparable vac numbers. M4F cam with 4 bbl and fentons.
The only other thing I can think of is that the top ring gap was on the high side. The clearance called for .016" on top ring, the actual was .021" or so. But still within spec. The 2nd ring was correct at .013" All rings were checked for gap clearance, and I'm pretty sure I got them installed rightside-up and staggered per instructions.
Basically should I continue to drive it, or park and figure out whats going on?
chip
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Chip, Are you sure you are not running too rich, enough to wash down the cylinder walls and make the rings leak?
#3367 10/09/2003 12:08 AM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I thought about that today... Would that show up when reading plugs?
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Those of you with the M4F cam. What is your idle speed? My engine idles very rough/stalls under 600 RPM. Maybe I have the valves set too tight or a vac leak.
I drove the car to work yesterday. Seemed to smoke less when I got home.
| | | | | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by chiphead: Would that show up when reading plugs? It might. It did on my son's. Your total miles is still low, but if it's running super rich you might be able to catch it this early.
Then you will know the truth, and the truth will set you free.
- Jesus -
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | hmmmmm,,,,,, are there any fuel additives in the tank? How old is the fuel in the tank? What fuel are you running? The vacuum readings look good by what you posted............ How is the coolant level? What do the plugs look like?
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Chiphead, I have the M4F cam. To start with my cam is not set straight up as they say. I have the cam advanced 4 degrees with a cam key, I think I used the std chevy V8 keys you can get from Jegs or the local speed shop. It sucks a steady 21 inches of vac at about 650 rpm but will go lower. As for valve settings - the cam card says to set hot at .014 and .016, however on mine it sounds like the hammers of hell and I can visualize the valve stems turning into mushrooms. So I re set a few times and the 235 appears now to like .012 & .014 on what they call regular fuel. The tighter the valve settings will move the power band up and along with it the rpm. If you go the other way and leave at .014 & .016 the engine will have lots of low end torque and will better match a stock 4.11:1 rear or a 3.90:1. Both these valve settings will have associated timing and plug color changes. Your engine will run cooler with more valve seat time; example .014 to .016 (.016 setting will allow more heat transfer to the cooling system) Good Luck. I ended up with a 165 therm and it runs a steady 170 or less even on the hot muggy days.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I've got 15-16" of vac at 800 RPM hot. Vac drops way down at 600 RPM & idles like a harley. Powerband is good from about 1000-up. Runs cool, etc. I think a few of my valves are too tight. I didn't readjust the valves after I broke the valvetrain down and installed the umbrella seals on the intakes. Also retorqued the head.
Coolant level has not decreased last time I checked it hot. Fuel was old, but ran it down to 1/4" tank and refilled with fresh 93 octane Shell gasoline from a new, big station. Plugs looked nice & tan when I went to change stem seals and did compression test cold. I've got 3.55 gears from a '54 'Glide car, so I need the low end torque to move that 4 door boat. But she'll do about 50 at 2000 rpm.
I'll prolly reset valves to what '52 suggests, adjust timing and idle mixture and post back. Any other things I should look at?
thanks guys!
chip
#3373 10/09/2003 11:55 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Your valves are definately too tight.
