1 members (Alex52),
136
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33593 12/23/2004 7:24 AM | Joined: Dec 2004 Posts: 12 Junior Member | | Junior Member Joined: Dec 2004 Posts: 12 | With rebuilding two to four 235 engines per year, head bolts, crank bolts and flywheel bolts are a real problem, at least a worry; I do NOT like using the same bolts again, and you should not.
I have made contact with ARP engineering and they have offered to manufacture those bolts for me. Currently, I need four sets (four engines) and am considering ordering between ten to twenty sets for a surplus.
Rod bolts, as you know, are a different beast and I am still giving thought to what can be done there.
Would you mind affording a quick opinion for me?
I will be testing the market for brand new engine bolts (not the pretty ones) for 235 engines. This will be head, crank main, rocker arm and flywheel bolts, only. Rods are out for now being a pressed knurled fit with a T head.
My experience is there is no source for these bolts. They cannot be found brand new. Do you, the reader, have a need or will have a need for bolt sets like this? Quick answer will do and your efforts are appreciated.
Billyray | | |
#33594 12/23/2004 8:49 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Hmmm ,, well I've only done 8 of the 216 engines , but I've never heard of an internal bolt failure , so I guess thats a NO from me. | | |
#33595 12/23/2004 12:39 PM | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | Just finished putting my 235 back together. Had removed the head while determining what needed to be rebuilt. Had the long block and head rebuilt by a pro and then I put the head back on using the original bolts -- must say I wasn't comfortable doing it. Did insure that they went back into their original holes. Did read a post somewhere about ARP bolts that could be used though not exactly the original length -- sounded scary to me (I didn't have a high enough level of confidence in my experience to make the decsion). I guess this is a long winded way of saying -- Had the correct bolts been available I would have purchased them. The same hold true for the internal bolts. So, YES!!! | | |
#33596 12/23/2004 3:00 PM | Joined: Dec 2004 Posts: 12 Junior Member | | Junior Member Joined: Dec 2004 Posts: 12 | Yes, you must use the correct length, always. Too deep, cracked head or broken bolt. Too shallow, bolt or head stripped threads.
Another danger is not cleaning threaded holes. Just a little oil or grease can crack a block.
A "dirty" hole, when a bolt is torqued down, can create so much hydraulic pressure a block can easily crack. Rocks, during construction, are often split this way. Drilled dynamite holes work the same way.
Torque bolts, such as head, crank and rod, must be replaced after use. They are designed to stretch a bit on torque which holds them in place. They do not "rebound" and return to normal after being torqued. Almost all manuals suggest you "throw away" your bolts upon a rebuild, especially head bolts.
Ok, one "no" and one "yes" on this question, so far. I hope others will add their thoughts.
Billyray | | |
#33597 12/23/2004 3:35 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | I'd be interested in a set of head bolts. Dave | | |
#33598 12/23/2004 10:25 PM | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | I don't know if 45 years of experience makes a difference, but unless the bolt is a "torque-to-yield" design, stretch isn't a factor. Try this experiment: Chuck a rod bolt in a lathe, and, using a small center drill, put a seat for a ball bearing in both ends of the bolt. (ARP bolts come with these holes already drilled.) Stick a BB-sized ball bearing to each end of the bolt with a little wheel bearing grease, and measure the length with a micrometer or a dial caliper. Torque the cap on, to specification, and measure the amount the bolt stretches. (ARP specifies .014" stretch on a Chevy 3/8" rod bolt) Repeat the procedure 50 times and see how much, if any, the unloaded dimension changes. Then, tell me whether or not I should re-use rod bolts. I do this on the 600+ HP, 7,500 RPM Chevy 350 race engines I build, and generally re-use the bolts several times. Head bolts are a no-brainer, unless they're rusty or have damaged threads, re-use them! Jerry
#33599 12/23/2004 11:01 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | The flywheel bolts are the same as for Chevy small block V-8,dime a dozen.The head bolts can be found for $2.25 each at Mcmaster Carr industrial supply online. They have many sizes of grade 9 special bolts.On a 235-261, a guy I know used Ford 351 Cleveland rod bolts,grind the side of the oval shaped head,use a washer under the nut,use those bolts when you have the rods sized at the machine shop.The mains? precision part, the grade 9 won't work unless you machine the bolt true like a dedicated main bearing bolt. | | |
#33600 12/23/2004 11:43 PM | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | I would buy an ARP bolt set for my application before I (with little experience) would go to 2 or 3 different sources to get what I think I need. Comfort Zone....
Yes, Buddy | | |
#33601 12/24/2004 3:49 AM | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Rebuilt my 235 head earlier this year with new valves, guides, etc. I had no problems cleaning and re-using my old head bolts. I didn't worry about getting a new set of screws, because I have been driving my six for about 60K miles in TX/CA temperatures with a clogged radiator and original driveline and 4:11. Never developed any head problems whatsoever and I didn't even know how long the engine was used before I got it. And the old head gasket was perfectly fine and would have sealed for many more years.
My point is, that it all depends how far you wanna go for yourself or your client. The 235 I drove for the past ten years, every day, seems to handle a lot more than screws streching a couple of micro inches.
Hail the old sixes...nothing ever like it. Can't wait for her 'good morning music' when I fire her up for another ride. | | |
#33602 12/24/2004 4:48 AM | Joined: Dec 2004 Posts: 12 Junior Member | | Junior Member Joined: Dec 2004 Posts: 12 | Hotrod Lincoln, thanks, lots of good info. Biggest 350 I have built is a 450 horse sitting in my old Corvette Mako Shark. For V eights, I always replace critical bolts with each rebuild, and I use ARP bolts. My concern is one stretched or broken bolt can ruin your Saturday night cruise.
Truckedup, I will pull out some old V eight flywheel bolts and compare. I am sure you are exactly right on that. Rod bolts, complicated. I have a 55 - 57 block apart now. Rod bolts are knurled and have a special T head. Not sure ARP will make those for me.
Buddy, yeah, I like doing it right, everytime. Too big of a risk to cut corners. I will go for the ARP bolts like you.
On the road again, a lot of these trucks I work on for family and friends, end up in deep snow, way out in the middle of nowhere, even up in Alaska where Buddy lives. I want all to be perfect and dependable. Breaking down in the wrong place might make you dinner for a grizzly!
A mixed bag so far. Langdon told me he does not worry about using the same bolts again.
A final comment, many of these engines we work on have over 100k, over 200k miles, are as old as me, they have been around and we don't know what has been done to them. Engine I took apart this past weekend, rod nuts were loose. Flywheel had 3 bolts of one type, 3 of another. Not good.
What I have in mind is to order at least ten sets custom made by ARP. Use three or four here, then offer the rest to whomever at my cost to test the market for 235 critical bolt packages. I think there is a small market for these bolts.
Just have to figure out what to do on those pesky rod bolts.
Thanks everyone for input. I hope more will come down from the peanut gallery and comment.
Merry Christmas to you and yours!
Billyray
I have a 56 3/4 ton Napco 4wd | | |
#33603 12/24/2004 4:59 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I concur with Hotrod, if it puts your mind at ease, you could mic the length of the bolts looking for a stretched spot. I usually always reuse headbolts unless there was a major overheat in the engines' life that caused major damage. I think the older iron was sometimes over engineered anyway, Scott | | |
#33604 12/24/2004 5:21 AM | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | I haven't had a 235 apart recently enough to remember what the rod bolts look like. The old 283's and early 327's had 11/32" rod bolts, and the 350's moved up to 3/8" diameter. ARP uses a super-strong alloy that needs 50 ft.-lbs. of torque, or the torque-to-stretch method of tightening. I'll bet an existing rod bolt could be fitted to the 235 rod, without having to have them custom-made, even if the hole in the rod has to be reamed to fit. The rod will need to be reconditioned after installing the new bolts anyway, something we always do when retrofitting to ARP race bolts. By setting up a jig in a valve seat and guide machine, and using valve guide reamers, I can make the rod bolt hole just about any size you want, accurately.
BTW, to get the correct amount of bolt stretch on a 7/16" diameter bolt in a Carillo rod for a 350 engine, it's necessary to use over 90 ft/lbs of torque. Those rods cost $1,000.00 per set, back when we were using them regularly. Jerry
#33605 12/24/2004 11:44 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | 235-261's use 1/2 inch main bolts in two different sizes, the rod bolts are 3/8 You never know where bolts have been in over 50 years, more likely than not ,over tightened by a past hack.New bolts are cheaper than running over your own crankshaft. You can't mike a bolt unless you know the length of each one when it was new.GM didn't machine each bolt to an exact length like ARP does. The 351 Cleveland rod bolts were suggested to my friend by ARP themselves as the diameter of the machined shank is exactly the same as 235 rod bolts.The grade 9 bolts from the industrial supplier are 170,00 psi, same as the "economy" bolts from ARP. If you're doing a low cost re ring and bearing job, the old bolts are probably Ok.But today ,with the cost of parts and machining for these old engines on a first class rebuild,it's cheap insurance to replace bolts. | | |
#33606 12/24/2004 4:58 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I intended to mic the diameter of a bolt along it's shank to find the stretched area, not the length. If a bolt stretches, it will "thin" down somewhere. It's also become a service procedure for a carmaker that I work for too. Scott | | |
#33607 12/25/2004 4:38 PM | Joined: Dec 2004 Posts: 12 Junior Member | | Junior Member Joined: Dec 2004 Posts: 12 | Your comments are very much appreciated. Please continue to add your thoughts.
Appears flywheel bolts for the 235 six will be a direct swap for virtually all early chevy engine flywheel bolts, inline and V8 alike.
Based on your comments, after New Year's, I will send ARP sample bolts. It will be suggested they compare a sample rod bolt to these,
Chevrolet: 283-327 and inline 6, ARP1346001
Ford: 351 Cleveland, 3/8 in, ARP1546003
My plan, on rod bolts, is if a direct replacement drop in cannot be found, I will have ARP make those rod bolts. I suspect most would rather have a drop in fit rather than having their rod ends and caps machined to accept a size other than original stock.
Head and crank bolts should be a simple matter of having ARP make them.
Biggest question now is cost. I will be ordering a moderate quantity to keep costs down. Still, the costs of these bolts will be significantly less than the cost of rebuilding an engine due to a crank or rod bolt failure and damage.
Comments on bolt age and fatigue are realistic. These engines are becoming old like us!
Thanks again and please keep commenting.
Merry Christmas to all!
Billyray | | |
#33608 12/25/2004 4:59 PM | Joined: Aug 2001 Posts: 1 Junior Member | | Junior Member Joined: Aug 2001 Posts: 1 | I think there are already Main Studs produced by ARP. I found a part# 132-5402, and was planning on using studs. Not cheap, $65 through Summit. I would be interested in rod bolts, if they fit the 261 rod. I know the rods for 235 and 261 are a little different. Do you thing they use the same bolts? | | |
#33609 12/25/2004 5:33 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | 55 and up 235 and 261 use the same bolts,try this place from the links right here on Stovebolt NOS parts they show 12 new rod bolts in stock#3836670 for 55 and up 235-261.i have bought from them several times, slow but reliable service. The stock 3/8 rod bolts are quite beefy for the power output,no need to change them unless you suspect they have been over torqued in the past | | |
#33610 12/25/2004 9:13 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | Godzilla, have you checked Chevs of the 40es? (yes they have 50es parts to) http://www.chevsofthe40s.com/ They sell them bolts out of the box. May be cheaper than have them custom made. yust my 2c Frank | | |
#33611 12/26/2004 6:02 PM | Joined: Dec 2004 Posts: 12 Junior Member | | Junior Member Joined: Dec 2004 Posts: 12 | jbrancheck, thanks! I have saved the ARP part number and will look at these. Their price is actually not too bad. I have paid a lot more for Chevy V8 bolts. That is a cheap price compared to damage done by a broken main bolt.
Truckedup, what method or system are you using to find original GM part numbers? That site is great but you have to pay for a part number. I will order those rod bolts and compare to what I have here. Thanks, I may have found at least one set of rod bolts. Again, how are you going about finding original GM part numbers? I would like to find part numbers for head/crank/ bolts.
Stovebold, I sent in email just minutes back asking about this difference between long and short head bolts. I don't have a clue which years or models use long or short bolts. I also asked them if they have a source for crank and rod bolts. Appears they have rod nuts. I will ask them if these are good for 55 and up rods.
Thanks again to all for great information. I am saving all this information and will share final results in the future so all will know how and where to obtain needed internal engine bolts.
Keep those comments coming!
Best,
Billyray | | |
#33612 12/26/2004 6:10 PM | Joined: Dec 2004 Posts: 12 Junior Member | | Junior Member Joined: Dec 2004 Posts: 12 | Truckedup, I am "trying" to order those rod bolts!
Everytime I click on their link to submit the information and order, an email compose page pops up. I will try to order through email.
Best,
Billyray | | |
#33613 12/26/2004 6:19 PM | Joined: Dec 2004 Posts: 12 Junior Member | | Junior Member Joined: Dec 2004 Posts: 12 | jbrancheck, here is what I am finding:
ARP 132-5402 2 bolt main Inline 6, ’54-62, without windage tray
I will order a set through Jeg's and see what I get! When they come in I will post and let you know if they work.
Best,
Billyray | | |
#33614 12/26/2004 6:25 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Godzilla, their web page is a piece of work, yes, email them.I have several old GM parts manuals as do some other guys here. head bolts numbers are;3835811 for the longer bolts,3835812 for the shorter bolts.For the mains,839126(1/2) for the rear main bolts,3835867 for front and rear intermediate main bolts(9/16).Flywheel bolts,839756,same for 235-261,283-350. | | |
